2014 jeep patriot
hemiboy29
Member - Posts: 22
Posted: January 20, 2014 at 9:04 PM / IP Logged
Hello I am installing an indash on my brother in laws car can someone please help me with the wire break down for this vehicle? I will also be installing a reverse camera so if you can supply me with a complete breakdown I will be greatly appreciated!
Chris G.
Platinum - Posts: 13,726
Posted: January 21, 2014 at 8:22 AM / IP Logged
Does it have the Boston Acoustic system? Or is it the standard audio system?
If standard, Metra's 70-6522 or xsvi6522 If it has the Boston System, it will use their CHTO-03 harness.
hemiboy29
Member - Posts: 22
Posted: January 21, 2014 at 12:33 PM / IP Logged
no its the basic radio i need to find a 12 volt feed because the harness that i bought doesnt supply it because factory radios nowedays uses the regular constant 12 volt and just drops voltage as per a buddy of mine who is an installer. I also need the reverse wire signal so i can connect the reverse camera. Thanks
Chris G.
burntkat
Copper - Posts: 159
Posted: January 21, 2014 at 5:48 PM / IP Logged
Not being witty or sarcastic at all- but perhaps it might be a good idea to have your buddy who is an installer do the install?
With all the networking, multiplexing, and such, going on in today's vehicles, taking it to a professional may well save money in the not-so-long run.
Believe me, I totally "get" the idea of DIY. But part of that is knowing when you need to "CTG" (Call the guy... who does know what he's doing)
"Always listen to experts. They'll tell you what can't be done, and why. Then do it. - Robert A. Heinlein"
powerslave
Copper - Posts: 126
Posted: January 21, 2014 at 10:58 PM / IP Logged
Your cigarette lighter will be Ignition +12, you can use that. I am using that for my OnStar System. Your AUX +12 will be constant.
soundnsecurity
Gold - Posts: 2,720
Posted: January 22, 2014 at 4:33 PM / IP Logged
not all cigarette lighter/12v sockets are an ignition feed, there is just as good a chance that it will be a constant feed. even in the same cars the behavior of the 12v sockets can be different for other trim levels. it is best to test the socket before you assume it will give you an ignition to tap off of.
burntkat
Copper - Posts: 159
Posted: January 22, 2014 at 6:16 PM / IP Logged
Absolutely agree. It's always best to test before implementation, anyway...
hemiboy29
Member - Posts: 22
Posted: January 22, 2014 at 9:01 PM / IP Logged
Perfect will do I love using my power probe so I will be testing and also fusing it!
Chris G.
burntkat
Copper - Posts: 159
Posted: January 22, 2014 at 9:45 PM / IP Logged
Hemi:
I'm sure you probably know this, but just in case:
Leave alone anything covered in yellow tape or tubing. It's the airbag and bad doings lie within..
powerslave
Copper - Posts: 126
Posted: January 22, 2014 at 10:30 PM / IP Logged
If you have a Dash area lighter socket, and then also have an AUX inside the Arm Rest, or on back of the Arm Rest, 9 out of 10, the one on the DASH is ignition +12. Most New Chryslers' are like that.
PLUS, anyone would be a fool not to test it first, that should go without saying, but apparently not... My bad...
