wiring subs to amp
jmcgee109
Member - Posts: 7
Posted: May 24, 2014 at 8:43 PM / IP Logged
Hi. I need some help. I have 2 audiobahn alum12m I want to wire to a hifonics BRX1600.1D. What's the best way to wire these subs up. Please help
Platinum - Posts: 13,725
Posted: May 24, 2014 at 9:33 PM / IP Logged
How many voice coils on each of the drivers? What is the impedance of said voice coils?
jmcgee109
Member - Posts: 7
Posted: May 24, 2014 at 9:43 PM / IP Logged
Dual voice coil. Impedance says 6 ohms
jmcgee109
Member - Posts: 7
Posted: May 24, 2014 at 9:54 PM / IP Logged
Now I'm reading where its a 2 ohm dual voice coil
Posted: May 25, 2014 at 7:24 AM / IP Logged
There are 3 images on the following link. The middle one is the best option for you. DO NOT USE THE TOP IMAGE.
https://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
jmcgee109
Member - Posts: 7
Posted: May 25, 2014 at 5:22 PM / IP Logged
So I wired then up like the middle one yesterday and my right sub froze and started smoking. Took it out and the right side above the mag was burnt out. Any thoughts
jmcgee109
Member - Posts: 7
Posted: May 25, 2014 at 5:24 PM / IP Logged
Oh and I had 2 more subs same rating same ohm and voice coil but old that I tried today wired the same. Same situation about 10 Mims of nice base and boom smoke and burnt. I'm thinking I have an amp issue. What do you guys think.
Posted: May 25, 2014 at 5:44 PM / IP Logged
There is not a problem with your amp. Buy some good speakers.
jmcgee109
Member - Posts: 7
Posted: May 25, 2014 at 6:03 PM / IP Logged
Are you being serious or your just not into audiobahns. I have used them in the past with no issues. What would you recommend.
jmcgee109
Member - Posts: 7
Posted: May 25, 2014 at 6:10 PM / IP Logged
Can you explain what the deal is why they keep burning up.
