95 4runner Radio works in aux, but not on
ponchosmule
Posted: March 16, 2015 at 1:12 PM / IP Logged Link to Post Post Reply Quote ponchosmule
I have a 95 4runner with an aftermarket Walmart head unit. When I turn my key to auxiliary the radio will come on. When I turn the truck on the radio shuts off like it loses power. The power button does nothing.
racerjames76
Silver - Posts: 581
Posted: March 17, 2015 at 7:55 AM / IP Logged Link to Post Post Reply Quote racerjames76
I was not aware walmart made radios. Obviously I am being a jerk and obviously you did not list the manufacturer of the radio. Even the cheapo radios have a part number somewhere on the faceplate.
It almost sounds like a ground issue...you would need to pop the radio out and use a volt meter to verify the 3 main wires. If the harness is using standard American wire colors (some cheap radios do not....be careful), you need to verify:
Black wire is grounded in all key positions
Red wire has 12v (roughly battery voltage)(no less than 11v and no more than 15v) in only accessory and run positions
Yellow wire (if the radio has a clock)(again some cheap radios do not have this) should have 12v battery voltage at all times.
If you need further assistance let us know!
To master and control electricity is perfection. *evil laugh*
ponchosmule
Posted: March 17, 2015 at 9:27 PM / IP Logged Link to Post Post Reply Quote ponchosmule
Sorry I was at work when I posted this. I will see if I can spot a brand name in the morning. This is not my DD and the weather was crap today. I will check brand and follow up. Thank you for the help thus far.
ponchosmule
Posted: March 24, 2015 at 6:14 PM / IP Logged Link to Post Post Reply Quote ponchosmule
Ok I took everything apart today.the strange thing is I unplug the harness from the back of the head unit to check voltage. Everything checks out. Plug it back in and it works just fine. Starting to think this head unit may crap out after it heats up??95 4runner Radio works in aux, but not on -- posted image.
Platinum - Posts: 13,725
Posted: March 24, 2015 at 9:55 PM / IP Logged Link to Post Post Reply Quote i am an idiot
It will not crap out after it heats up. It will probably crap out before it heats up.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
