Overall System Help!
TamsR
Posted: May 22, 2003 at 10:25 PM / IP Logged
Hello Everyone!
The name is TamsR and I'm new to The 12volt.
Ive been out of the Car Aduio sceen for a few years and
now trying to get back into it all. Man, have things changed.
I have few questions about my overall system. Any help would be Great.
I have all the gear and I plan on Installing within the next couple of days.
All Equipment is going to be installed in a 2003 Jeep Liberty Renegade (4-Door).
First off, Here is all the stuff I have:
• Mids/Highs Amp - 4ch PPI PowerClass (PC4200)
Specifications: Output Power: 4 Ohms 4X25W Output Power: 2 Ohms 4X50W Output Power: 4 OHM-MONO 2X100W THD: 0.02% S/N RATIO: 110 dB FREQ. RESP: 4.5-100K I/P SENS: .15-12V DAMPING: >500 DIMENSIONS 2.25” x 8.9”: x 12.75 QBASS EQ: QBASS X/O SLOPE: 12, 24dB/OCT. X/O FREQ: 20-5k, 90Hz X/O TYPE
• Sub Amp - 2ch PPI PowerClass (PC2400)
Specifications: Output Power: 4 Ohms 2X100W Output Power: 2 Ohms 2X200W Output Power: 4 OHM-MONO 1X400W THD: 0.02% S/N RATIO: 115 dB FREQ. RESP: 4.5-100K I/P SENS: .15-12V DAMPING: >500 DIMENSIONS 2.25” x 8.9”: x 15.75 QBASS EQ: QBASSplus X/O SLOPE: 12dB/OCT. X/O FREQ: 20-5k X/O TYPE
•  (3)10inch JL Subs in a Sealed Box (CS310RG-W0)
Power Handling: 375W Continuous
Drivers: Three 10W0-8
Final Impedance: 2.7 Ohms Mono
Sealed enclosure / Rear-firing design
http://www.jlaudio.com/enclosures/CS310RGW0.html#
• Diamond Audio S600s HeX Series (Front)
6.5 Inch HEX Component System with Silk Tweeter and 2 separate Crossover Networks.
• Boston Acoustics RX67 (Rear)
6.5 Inch coaxials
• Pioneer CD Player DEH-P8200
Hi-Volt RCA Preouts (x3 pair) (Front/Rear + Subwoofer) (Non-clipping 4.8V max)
Front/Rear HPF (50/80/125Hz, -12dB/Oct.)
Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
MOSFET45 (45Wx4-Channel High Power)
• SteetWires 4 Gauge Power Wire
• SteetWires Distribution Block
• SteetWires In-Line Fuse Holder
• SteetWires 8 Gauge Power Wire (After the Distribution Block)
• SteetWires 14 Gauge Ultra Cable Speaker Wire.
• SteetWires Battery Terminal
Now For the Questions:
My Deck & Amps both have built-in crossovers.
Which one do I use?
The one from the Deck? The one from the Amps? Or Both?
What Crossover whould be good for this system?
• In my previous vehicle I had a trunk. Now I own a SUV which is not enclosed anymore.
Should I use the same box? Whats the best Box/Subs set-up for my SUV?
I have a sealed box right now. Im trying to get the best overall Sound Quality.
• Whats the best way to connect my Subs to the amp? Theres a (+) & (-) comming
from the box with (3) 10's.
• I was planning on installing my 6.5inch Component System in the door,
but if I do, Ill have to cut the tweeters in the door. I really dont want to do
that because Ill have to leave the tweeters in the once I sell it later on.
There is a factory location in the dash but I wasnt sure if this would be too much
space between the Tweeter and the driver. How far away can the
Tweeter be away form the Driver before it starts to sound crappy?
If you have any other Advice for me, please Sound Off! Overall System Help! -- posted image.
Thanks In Advance!
TamsR
Posted: May 22, 2003 at 10:28 PM / IP Logged
LOL...Sorry about the Smiley Face....I not able to Edit my Post!
Nestamarley
Member - Posts: 12
Posted: May 23, 2003 at 12:02 AM / IP Logged
  well I'm new here myself, and let me say you have come to the right place. These guys know their stuff, and I'm learning alot.
  As far as your questions go... If it were me I would use the deck for your sub crossover so you could tune it on the fly, depending on your mood and music and use the amp crossover for your mid and high (make sure your freq. overlap a bit for clarity). For your subs I would not change the box, as that box was made specificly for those speakers and is tuned accordingly. As far as the hook up look at my forum string I just got "taken to school" on all that and it will help you in your endever as well I think. http://https://www.the12volt.com/installbay/forum_posts.asp?tid=13746&tpn=2
"In this bright future you cant forget your past"
