2014 Nissan Murano radio pinout pin-out needed
leehall
Posted: April 20, 2015 at 12:59 AM / IP Logged Link to Post Post Reply Quote leehall
Anyone out there have a pin-out for a 2014 Nissan Murano radio? I'm guessing that might be the easiest place to get what I need. I'm looking for BAT(+12V) and Accessory(+12V) to use for some third party accessories (cell amplifier, radar detector, USB charger).
Thanks so much for any guidance you can offer.
-- Lee
tonanzith
Gold - Posts: 603
Posted: April 20, 2015 at 2:47 PM / IP Logged Link to Post Post Reply Quote tonanzith
Radio 12V     yellow     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis) or black (some models only)     -     radio, white 20 pin plug, pin 20
Radio Ignition     red or white     +     radio, white 20 pin plug, pin 7
Radio Illumination     red (parking lights), lt. blue (dimmer)     +,-     radio, white 20 pin plug, pins 9 and 8
Factory Amp Turn-on     pink     +     radio, white 12 pin plug, pin 9 or white 20 pin plug, pin 1
Power Antenna +     radio, 3 pin plug, pin 1
Left Front Speaker (+/-)     blue - black or red - green     +,-     radio, wht 20 pin plg, pins 2 and 3 or wht 12 pin plg, pins 12 and 6
On models with amplifier, the speaker wires are white - black at the amplifier under cargo floor, brown 23 pin plug, pins 4 and 5. The tweeter wires are lt. green - purple at the amplifier, brown 14 pin plug, pins 1 and 2.
Right Front Speaker (+/-)     brown - white, white - blue, or white - black     +,-     radio, wht 20 pin plg, pins 11 and 12 or wh 12 pin plg, pins 8 and 2
On models with amplifier, the speaker wires are brown - yellow at the amplifier under cargo floor, brown 23 pin plug, pins 17 and 18. The tweeter wires are pink - blue at the amplifier, brown 14 pin plug, pins 4 and 3.
Left Rear Speaker (+/-)     lt. green - yellow or red - blue     +,-     radio, wht 20 pin plg, pins 4 and 5 or wht 12 pin plg, pins 11 and 5
On models with amplifier, the speaker wires are green - red at the amplifier under cargo floor, brown 23 pin plug, pins 14 and 1. The surround wires are gray - brown at the amplifier, brown 23 pin plug, pins 2 and 3.
Right Rear Speaker (+/-)     gray - pink or lt. green - purple     +,-     radio, wht 20 pin plg, pins 13 and 14 or wh 12 pin plg, pins 7 and 1
On models with amplifier, the speaker wires are blue - orange at the amplifier under cargo floor, brown 14 pin plug, pins 14 and 9. The surround wires are gray - brown at the amplifier, brown 23 pin plug, pins 2 and 3.
Center Channel (+/-)     purple - pink     +,-     amplifier under cargo floor, brown 23 pin plug, pins 15 and 16
Subwoofer (+/-)     gray - brown or yellow - brown     +,-     amplifier under cargo floor, brown 14 pin plug, pins 13 and 8
Aux. Audio Input Left (+/-)     black - white     +,-     radio, white 32 pin plug, pins 28 and 27
Aux. Audio Input Right (+/-)     red - white     +,-     radio, white 32 pin plug, pins 29 and 27
The aux. video wires are yellow - brown at the radio, white 16 pin plug, pins 2 and 10.
RSE Video (+/-)     lt. green - purple or blue - pink (front display)     +,-     radio, white 24 pin plug, pins 12 and 11
The rear view camera wires are red - (shield) or yellow - (shield) at the radio, white 16 pin plug, pins 3 and 12 or 3 and 4.
RSE Audio Left (+/-)     green - black (satellite audio)     +,-     radio, white 12 pin plug, pins 1 and 5
RSE Audio Right (+/-)     white - red (satellite audio)     +,-     radio, white 12 pin plug, pins 2 and 6
Satellite Radio 12 Volts     purple     +     Sat Radio under cargo floor, wh 16 pin plg, pin 12
Satellite Radio Ground     black     -     Sat Radio under cargo floor, wh 16 pin plg, pin 15
Satellite Radio Ignition     gray     +     Sat Radio under cargo floor, wh 16 pin plg, pin 16
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     yellow/blue - WHITE/ blue     +,-     Satellite Radio, white 16 pin plug, pins 2 and 1
Satellite Audio Right (+/-)     BROWN / blue - YELLOW /GREEN     +,-
Gary Sather
