I math & ohms.
speakeasypete
Posted: August 01, 2015 at 2:49 PM / IP Logged Link to Post Post Reply Quote speakeasypete
I visited the ohms calculator and still can't figure out how they came up with the sum.I was thinking of connecting three 4 ohm speakers in parallel.My math shows 5.3, calculator shows 1.3.Can some body explain?
p,/
Platinum - Posts: 13,725
Posted: August 01, 2015 at 8:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Anytime you parallel 2 resistors or voice coils, the outcome is always lower than the lowest value resistor in the equation. The correct answer it 1.3333
Anytime you parallel 2 like value resistors it simply cuts that value in half. 4 plus 4 = 2   When you parallel the now 2 ohm load with the 3rd 4 ohm driver the math is 4+2=6   4x2=8 8/6=1.333333 There is more to the equation but this is how Ohms law comes up with the answer.
Posted: August 01, 2015 at 9:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
knudsen
Member - Posts: 17
Posted: August 05, 2015 at 6:30 AM / IP Logged Link to Post Post Reply Quote knudsen
When all the resistor (or VC) values are the same, there is a shortcut. Just divide the value in ohms by the number of resisters or VCs in parallel.
4ohm/3 = what i am said
Keeping in mind that VCs are seen by AC or an audio signal as impedance, or in practice an LRC circuit, and impedance varies with frequency, IMHO it would not be best practice to parallel VC's to a value that is very close to the minimum rating of the amp. That's why the VC's impedance is "nominal." At lower frequencies, less impedance is seen by the amp. With variations between speakers, and other factors that create an unknown and unwanted LRC circuit, when you parallel, the impedance becomes "nominal and approximate." Not saying parallel is bad, just saying cover you assmp. 1.33 ohms is too close for me, but YMMV, and the pro's here have 1000 X the practical experience that I do.
Build a man a fire, he keeps warm for a day. Set a man on fire he stays warm for life!
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
