sub enclosure type
Craig Fletcher
Posted: May 26, 2003 at 5:57 AM / IP Logged
sub enclosure type -- posted image. Hi all , im new on here so be gentle .
ive went and done things the wrong way round (as usual) and seen subs bought them and then
thought about how to fit them . I was going for a simple sealed enclosure for my 2 focal 33a 13" 400wrms subs ,
but the thing is in the destructions that come with them it only gives box dimensions for a ported enclosure so im wondering
if i put them in a sealed unit will it damage my new babies? i dont want big boomy bass but tight stuff for quality so a bit confused about where to go from here any ideas appreciated Craig
alfa155.com
DYohn
Platinum - Posts: 10,741
Posted: May 26, 2003 at 9:05 AM / IP Logged
Hi.  The Focal Access 33a is a relatively new German fiberglass cone woofer designed for a bass-reflex (vented) enclosure of 30 to 45 litres.  It can also be mounted infinite baffle (free-air.)  A sealed anclosure could be designed for it but it will not perform as well as in a vented one.  Here's the Theil Small's for this driver.
fs = 29 hz
Qts = 0.62
Vas = 124 Litres
Xmas = 9 mm
Craig Fletcher
Posted: May 26, 2003 at 12:10 PM / IP Logged
thank D but ive got this info on the sub but i think youve got mixed up info as mine is
fs 47.37hz , qts0.575 , vas 27.12 litres and xmax 7.5mm and they are french im not trying to sound off but letting you know .
alfa155.com
Craig Fletcher
Posted: May 26, 2003 at 12:17 PM / IP Logged
anyone else got any suggestions on this ? anyone using these speakers are they too boomy in a vented box?after all i do have to carry the little one around in the car sometimes.
alfa155.com
bdl666
Silver - Posts: 330
Posted: May 26, 2003 at 2:30 PM / IP Logged
     I ran those specs on WinIsd Pro  and on Blaubox and it seems like a 53 litres enclosure should be fine for them. I say try it and see how they sound.
Craig Fletcher
Posted: May 28, 2003 at 3:55 AM / IP Logged
Thanks a lot bd166 , sorry to go on but was that a single woofer enclosure or for both in one box i tried blaubox but got quite confused by it all
as i said im new to all this thiel buisness and im trying to get as many opinions as poss thanks again for your time , ps if your ever in liverpool england ill show you how it turned out !!!!!!sub enclosure type -- posted image.
alfa155.com
