40hz-120hz: I need 8'' subs to fill this range
marcianello
Posted: May 27, 2016 at 6:13 PM / IP Logged Link to Post Post Reply Quote marcianello
My Soundstream 12 is in a ported box tuned to 35hz. When you play bass test tones it really starts to get loud below 40hz. It has a few holes in the spectrum above 40, and everything up to 100 is basically missing. Before I choose component sets for the mids & highs, I want to add a pair of 8" subs mounted on my rear pillars to fill in the missing octaves. My 6.5" drivers usually start around 120hz.
Has anyone had success with a particular sub? I plan on using around .3cf/each sealed, most 8" subs tune much lower when you port them. I dont need anything below 40hz. I found a JL Audio 8W1V3-4 for $130 on Crutchfield, but before I order a pair Id like to get some opinions. Is there a magic woofer that operates well in a small enclosure between 40-100hz? I will probably have a Zapco ASP-Q1 EQ/X-over unless I find something better. (I like knobs.)
1969 Mustang
Pioneer DEH-P5100-UB
Boston Coaxials
Zapco I-Force i2100
Soundstream SPL-X122hf
marcianello
Posted: May 27, 2016 at 6:25 PM / IP Logged Link to Post Post Reply Quote marcianello
The title was supposed to read "40hz-120hz: I need 8" subs to fill this range"
1969 Mustang
Boston Coaxials
Zapco I-Force i2100
KarTuneMan
Platinum - Posts: 7,056
Posted: June 21, 2016 at 10:06 PM / IP Logged Link to Post Post Reply Quote KarTuneMan
Hybrid Audio makes 2 8 inch drivers. 30 to 1000hz
marcianello
Posted: June 21, 2016 at 10:35 PM / IP Logged Link to Post Post Reply Quote marcianello
Thanks, I took a look and they seem to perform well. Looks like the 8" only needs .75cf, do you have any experience with these?
1969 Mustang
Boston Coaxials
Zapco I-Force i2100
geepherder
Platinum - Posts: 3,668
Posted: June 22, 2016 at 12:12 AM / IP Logged Link to Post Post Reply Quote geepherder
I've had a JL 8W3 (V2 I think) for several years and it's great. It's in a small enclosure (just under .3 cu ft).
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
