Will this Sub & amp config work?
lukesc1993
Posted: December 27, 2016 at 3:28 PM / IP Logged Link to Post Post Reply Quote lukesc1993
Hi all,
I live in UK and own a 2010 Honda Civic Si, 5 door, 1.8L. I also have a "15" Pro-Plus NBP-1500VS" sub in a sealed enclose along with a "Boss Riot R1100m Monoblock" amplifier.
All I want to do is add the sub to the existing stereo setup & wanted to know if the amp had enough power for the sub.
Sub:
Pro-Plus NBP-1500VS
15"
500W - 4Ohm SVC
12" Width x 18" Depth x 18" Height
Amp:
Boss Riot R1100M Monoblock
Class A/B
1100W x1 @ 2Ohm
250 x1 @ 4Ohm
mohpro
Member - Posts: 38
Posted: December 27, 2016 at 6:10 PM / IP Logged Link to Post Post Reply Quote mohpro
Are the power ratings you posted for both the sub and the amp Max power ratings or RMS?
lukesc1993
Posted: December 28, 2016 at 3:49 AM / IP Logged Link to Post Post Reply Quote lukesc1993
For the sub the peak is 500W so RMS must be 250? And the amps manual says "RMS power - 250 x 1 into 4Ohms"
Platinum - Posts: 13,726
Posted: December 28, 2016 at 8:14 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Read the above post.
