2005 equinox aftermarket radio install
sammmiller
Posted: January 02, 2017 at 10:59 AM / IP Logged Link to Post Post Reply Quote sammmiller
Trying to install a Kenwood in equinox with factory equipment. Installed axxess gm data interface to retain chime. Everything works except no sound out of speakers. Speakers work with factory system.
Sam
Platinum - Posts: 13,726
Posted: January 02, 2017 at 2:15 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Is there a blue or a blue white wire on the Axxess harness?
sammmiller
Posted: January 02, 2017 at 2:21 PM / IP Logged Link to Post Post Reply Quote sammmiller
Yes.blue with white stripe.
Sam
Posted: January 02, 2017 at 2:28 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What did you connect to that wire?
sammmiller
Posted: January 02, 2017 at 2:34 PM / IP Logged Link to Post Post Reply Quote sammmiller
Nothing. Kenwood has that wire labeled P.CONT ANT.CONT.I read that as meaning power antenna.Can dose not have power antenna.
Sam
Posted: January 02, 2017 at 2:52 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The blue white of the axxess piece is the amplifier turn on wire. Connect it to the p. cont wire.
sammmiller
Posted: January 02, 2017 at 2:56 PM / IP Logged Link to Post Post Reply Quote sammmiller
I will.Do you know what the corresponding wire color in the chevy harnesses should be ? I want to make sure wire in axxess harness is in the proper pin hole.
Sam
Posted: January 02, 2017 at 3:37 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Pink
sammmiller
Posted: January 02, 2017 at 4:09 PM / IP Logged Link to Post Post Reply Quote sammmiller
Yes it works. Thank you so much for volunteering your time and knowledge.
Sam
Sam
