86 Crown Vic wiring
stanman8810
Posted: May 31, 2003 at 8:35 PM / IP Logged
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1986-89&make=Ford&model=Crown%20Victoria&ID=17758&type=Stereo
In this wiring chart, for the rear speaker connections, it shows LR+ > pink/green; LR- > pink/blue; RR+ > pink/blue; RR- > GREEN/ orange. Why would LR- and RR+ be the same colour? It would make more sense for both grounds to be the same colour, like it is for the front speakers. Could it be a typo?
Okoboji
Member - Posts: 35
Posted: May 31, 2003 at 8:41 PM / IP Logged
If your concerned about it being a typeo test it out on your car or just get a wiring harness
belfour
Member - Posts: 13
Posted: May 31, 2003 at 11:05 PM / IP Logged
some older fords used the common groung method so they may be the same colour, but the best bet if it is common ground is to run new speaker wire, it will sound better
stanman8810
Posted: June 01, 2003 at 8:29 AM / IP Logged
I'm sorry, I probably should have mentioned in the first post that the factory harness in the dash is gone and I have to figure out which wires are which to install another stereo.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
