2009 Sonata Stereo, Power, No Sound
sparxx_513
Member - Posts: 33
Posted: May 29, 2018 at 10:18 PM / IP Logged Link to Post Post Reply Quote sparxx_513
Have a 09 Sonata Limited with Infinity system. Installing a Pioneer AVH-2300NEX, using a Metra 70-7303 Harness. Radio powers up but no sound. I am getting power to the factory amp turn on ( Red plug with single wire on the 70-7303). Any ideas? One post i seen suggested using a converter to send the factory amp a low level signal. i tried this also with no luck. Do i have any other options besides bypassing the factory amp all together? If not does anyone have a scematic of the factory amp?
mgoetz74
Silver - Posts: 424
Posted: May 30, 2018 at 11:30 AM / IP Logged Link to Post Post Reply Quote mgoetz74
should be a pink/black wire two spot over from where the remote turn on is now. run the remote turn on to that pink/black. Its a known issue with the 70-7303 harness that it is in the wrong pin location. If you listen to am radio make sure you also hook up the solid blue wire on the 70-7303 harness, there is a amplified tuner in the car for am stations
Sunday, January 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
