If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, December 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
My questions are:
1. What is the red wire and brass spade prong for?
2. In the instructions it says to connect the resistor to the "aftermarket amp turn on wire" which I hope is the "remote turn on +" coming from the aftermarket radio harness, is that right?
3. The instructions say to connect the "aftermarket amp turn on +" (WIRE 3?) to one end of the resistor, & connect the other end of the resistor to the two blue/white wires (WIRES 2 &3) **but** do I need to also connect the blue/white wire from the WH-004 harness the goes to the stock wiring harness (WIRE 4)?
Picture to show wire numbers:
