Nissan/Datson 280ZX
mwatson
Posted: June 11, 2003 at 11:04 AM / IP Logged
I ahev a 280ZX turbo and teh raddio is tornout of it any body have the wiring diagram and any helpfull hints??? Thanks all!!!
Sweekster
Silver - Posts: 481
Posted: June 11, 2003 at 2:45 PM / IP Logged
You might wanna try this diagram.  If not, you might just have to get a multimeter and start checking all the wires. An easy way out (which I don't really recommend doing) is, if you're putting in a new aftermarket head unit is connecting the 12volt memory (yellow) wire and the switched 12volt (red) together and then running a wire from the positive terminal  (with an inline fuse) on the battery to them and connecting the ground to a clean chasis point.  Doing that will give it power but you will have to manually turn it on and off and you'll be running the risk of draining your battery.  It's better if you find the right wires and connect them that way  Good luck
Sweekster
Silver - Posts: 481
Posted: June 11, 2003 at 3:50 PM / IP Logged
Something else you could try if that diagram doesn't work is this explantion of how to find the proper wires.
