FM Modulator grounding problem
parody
Posted: June 12, 2003 at 5:42 AM / IP Logged
Hi All,
I installed a (Pyramid?) fm modulator in my Toyota Sienna, to get audio input from a dvd. I noticed that I was getting a high pitched whine when the engine was on, so I assumed I had a grounding problem.
I tapped into power from an auxiliary 12v jack, and grounded to a bare metal portion of the body. As I was fiddling around with it, I deliberately cut the ground wire, expecting the FM modulator to stop working. However, it did not!
It's obviously grounding thru the antenna wire. Is this FM modulator defective -- it's not supposed to work this way, right????
Thanks!
esmith69
Gold - Posts: 1,511
Posted: June 12, 2003 at 8:15 AM / IP Logged
Actually it is supposed to work that way, but usually you need a better ground than just the one in the antenna.  After cutting the grounding wire, are you still getting the high pitched whining sound?  What year is the sienna, and have you tried one of these antenna noise filters?
Finally, does the pitch of the whining sound change along with the engine RPMs?  Or does it stay constant the whole time?
Ethan
Donate to the12volt.com
parody
Posted: June 12, 2003 at 10:27 AM / IP Logged
Yes, it the whining sound changes with RPM's. It's a 2003 Sienna. I haven't tried an antenna noise filter.
I had my wife pick up one of these:
Ground loop Isolator
We'll see if that makes any difference. Otherwise, try a noise filter?
esmith69
Gold - Posts: 1,511
Posted: June 12, 2003 at 11:19 AM / IP Logged
The ground loop isolator could very well fix your problem.  If not, also make sure the head unit has a good ground connection.  And then the next step if it's still getting the noise would be to try one of these alternator whine noise filters.
Ethan
parody
Posted: June 13, 2003 at 6:17 AM / IP Logged
Yes, the ground loop isolator solved the problem -- no more whine!
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
