just a few install questions
saleengt
Copper - Posts: 73
Posted: July 03, 2003 at 10:33 PM / IP Logged
when doing amp installs where do most installers hide the excess wires? also when doing mobile video installs and installing the dvd unit do you run another wire off the ignition wire for the dvd unit?
esmith69
Gold - Posts: 1,511
Posted: July 03, 2003 at 11:06 PM / IP Logged
If it's a cable like an RCA we just gather it up and zip tie it, or if the extra needs to go under the carpet or something, we spread it out so that there arent' a lot of bumps from the cable.  Every vehicle is different though, and within that everyone has different equipment, so it's kind of hard to say specifically how to do it.
For speaker wires, and power and ground, we almost always cut it to length just to make for a cleaner install.  Ground cables should always be as short as possible and if you find yourself having to coil up your grounding cable, that means it's way too long and should be shortened.
If you hook up the switched wire of the dvd unit to a constant wire with a relay and a switch inline, then if you're watching a movie with the car off, when you finally decide to turn the car on the dvd player won't shut off and reset.  If you do it this way you just have to remember to turn it off whenever you leave the vehicle cuz otherwise it will stay on and run down your battery.
Ethan
Donate to the12volt.com
ghs_wreslter189
Copper - Posts: 52
Posted: July 04, 2003 at 4:11 PM / IP Logged
I just bunch up the excess wires under the rear seat.  It has always worked well for me.
--Adam
wvsquirrel
Gold - Posts: 1,237
Posted: July 04, 2003 at 11:32 PM / IP Logged
Like esmith69 said, you can get away with doing that to speaker, RCA, remote, and power cables. But Ground should always be as short as possible. I always try to keep any cable as short as possible.
Believe it or not, I've had wires get hot enough to melt into the floor coating and make their own "channels" on the floor! And I'm not talking poorly insulated cables either. About the only time you would need to bunch up cables is if you plan on moving the equipment into another vehicle and don't have or don't want to spend the money on new/longer cables. It's usually best to keep it as simple as possible and cut the cables to the proper length.
Squirrel
"No more Cpt. Kirk chit chat"
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
