head unit suggestions
Bellmerser
Posted: July 03, 2003 at 10:41 PM / IP Logged
I need a new head unit since my old one broke, so i've been looking at two or three different units. The alpine http://www.mmxpress.com/alpine/alpine_cda-7998.htm, the jvc http://www.mmxpress.com/jvc/kd-sh55.htm and finally the eclipse cd8053 or the 8443. http://www.eclipse-web.com/products/cdtuner/top.html
my main concern is music reproduction, followed by mp3 capability, then crossover type and performance, followed by looks. money does play a small factor, other wise i would just go by an alpine f#1 =)
DYohn
Moderator - Posts: 10,741
Posted: July 04, 2003 at 8:06 AM / IP Logged
Alpine or Eclipse are both fine choices.  I have never liked JVC head units, though.  Just my 2 cents....
bberman1
Gold - Posts: 2,314
Posted: July 04, 2003 at 8:32 AM / IP Logged
I would suggest either the cd8053 or the 8443. The eclipse will give you some awesome sq and the sound is very dynamic. However the only draw back is if you want to be able to play MP3's you need the optimal Eclipse Commander http://www.eclipse-web.com/products/e-com/index.html
Tfire5
Member - Posts: 8
Posted: July 04, 2003 at 3:46 PM / IP Logged
eclipse and alpine are both great choices but if you are into sq more than looks check out nakamichi as well.but between alpine and eclipse i personally would run eclipse they sound better and most have higher voltage pre outs and they are supposed to have a more powerfull antenna so that regular stations have less tendancy to fuzz out when your jammin.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
