what happen if i connect
profuse007
Gold - Posts: 2,015
Posted: July 28, 2003 at 1:48 PM / IP Logged
-what happen if i was to bridge that subs right but put in the RCA wire backward. so another word, i bridged it wrong.
-what exactly happen if you over heat the amp? what does it crash?
Houston,TX
bberman1
Gold - Posts: 2,314
Posted: July 28, 2003 at 3:11 PM / IP Logged
On a mono amp it dose not matter which way the RCA's are connected.
xetmes
Silver - Posts: 586
Posted: July 28, 2003 at 3:59 PM / IP Logged
If you overheat the amp it may shut it self down, it may stop working forever, or it may light on fire.
profuse007
Gold - Posts: 2,015
Posted: July 28, 2003 at 7:29 PM / IP Logged
well of course you cant bridge a mono amp, so you the rca doesnt matter. but what happen if i bridge it wrongway?
Houston,TX
bberman1
Gold - Posts: 2,314
Posted: July 28, 2003 at 8:26 PM / IP Logged
If it’s bridged the wrong way you run the chance of damaging the amp and your subs. Not to mention you probably would not get any sound
Monday, July 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
