MA audio amp HK-1997?
dr_jdelara
Member - Posts: 37
Posted: August 02, 2003 at 12:58 AM / IP Logged
Do yall think this amp which runs at 1200 w at 2 ohms would be good for my 2 12" kicker comp vr's?
bberman1
Gold - Posts: 2,314
Posted: August 02, 2003 at 6:18 PM / IP Logged
I don’t see a problem, that amp should put out some good clean power to those subs. The only thing you need to be careful about is not to turn up the gains too high since, that amp dose out power the subs.
testes
Member - Posts: 29
Posted: August 03, 2003 at 9:30 AM / IP Logged
I have that amp and i would recommend it.  I am running the amp at a one ohm load since my subs are dual voice coil subs and i need the power .  The only bad thing about the amp is that it is an ab class amp, so it draws some  current.
fatdaddyjoe
Copper - Posts: 129
Posted: August 03, 2003 at 11:10 PM / IP Logged
i have two of those amps running at 2 ohms pushing 4 15" audiobahn aw150 q and they kick a$$......i would recommend these amps to anyone..........
the louder the better !!!!!!
can you feel it ?????
