wiring stereo
toned
Posted: August 02, 2003 at 10:33 PM / IP Logged
can anyone tell me the color codes for the wires in a 03' explorer.
esmith69
Gold - Posts: 1,511
Posted: August 03, 2003 at 12:20 AM / IP Logged
I think it just uses the one of the two '98-up ford harness ( Metra 70-5700 if it has a factory subwoofer; Metra 70-1771 if it does not).
Other than those pictures, the only thing I have is this diagram of the back of a radio that should be similar to the back of your radio.  With the factory connector plugged into the back of the radio you can look at the diagram and figure out which wires are which.
Ethan
Donate to the12volt.com
esmith69
Gold - Posts: 1,511
Posted: August 03, 2003 at 12:23 AM / IP Logged
okie just found the wiring for the 02 explorer but I don't know if it's gonna be the same as your vehicle's wiring.  As long as you have the same size/shape plugs as the ones in the diagrams I showed you, you know that you can follow the pinouts if unsure.  They may use different colors for the factory wiring, but between models that have the same size/shape plug, all of the pinouts are the same.
+12V Constant = WHITE/ Yellow
+12V Accessory Switched = BLACK/ Pink
-12V Chassis Ground = BLACK/ Orange
+12V Illumination = RED / Black
Varying 12V Dimmer = Black
LF+ = ORANGE / Green
LF- = Blue/White
RF+ = WHITE/ Green
RF- = GREEN/ Orange
LR+ = Gray/Blue
LR- = Tan / YELLOW
RR+ = ORANGE / Red
RR- = BROWN / Pink
Ethan
toned
Posted: August 04, 2003 at 5:50 AM / IP Logged
i need o3' explorer wires. they must be different because other than the speaker wires i have a BLACK/ green, ORANGE / black, gray/orange, YELLOW /GREEN, and solid black.
toned
Posted: August 05, 2003 at 5:49 AM / IP Logged
myabe, i should've been more specific. i'm trying to install a 03' stock stereo in my 91' f-150. I have a harness for my truck but i don't know which wires go where from the newer model. i need to know what the color code is for the 03' model to match it up.
in case you are wondering, my uncle works for a waste management company that picks up loads from Visteon. For some reason they were dumping a bunch of stock radios (probably for changeover) and he gave me one.
i got the radio to work but it's not right. i've got some wires crossed and i don't know where. I've got the speaker wires figured out but the memory, dimmer, ground etc... is giving me problems.
