Confused with combining fuses
cchoi112
Posted: August 05, 2003 at 6:27 PM / IP Logged
I currently am running two amps, each with a 30A inline fuse, from a single battery.  If use a distribution block and also a single inline fuse holder to support both amps, what should the amperage be of the fuse on the "new setup"?
Thanks.
Colin
bberman1
Gold - Posts: 2,314
Posted: August 05, 2003 at 6:32 PM / IP Logged
Your main fuse at the battery should be 60 amps, the 2 fuses in the fused distribution block should each be 30 amps.
xetmes
Silver - Posts: 586
Posted: August 05, 2003 at 7:25 PM / IP Logged
I second that Confused with combining  fuses -- posted image.
Sunday, January 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
