FM Modulator
captain_dmr
Posted: August 17, 2003 at 8:48 AM / IP Logged
A while back I posted a message about taking an output from an mp3 player and wiring it into my car radio. It was recommended that I use an FM modulator. Err.. could anyone tell me; what is, it how does it work, what kinda sound quality will I get and how much will it cost??????
The original post was https://www.the12volt.com/installbay/forum_posts.asp?tid=15650&PN=27
if you wanted to know
Thanks Liam
esmith69
Gold - Posts: 1,511
Posted: August 17, 2003 at 9:03 AM / IP Logged
http://www.crutchfield.com/cgi-bin/S-90i9FpAsbn3/ProdView.asp?s=0&c=2&g=42500&I=257KSIF200&o=p&a=1&cc=01&avf=Y
Ethan
Donate to the12volt.com
brianh
Silver - Posts: 518
Posted: August 17, 2003 at 10:51 AM / IP Logged
A FM modulator is a device that allows you to feed sound from another source(dvd,mp3,ect)into you radio when your radio does not have a audio input. They are really simple to install. You will have to remove your radio to get at the wires behind it. Hook the 12 volt feed to the switched wire at your radio. Ground the ground wire. Then unplug your antenna fromt he radio. Plug the antenna from the car into the modulator and then plug the modulator into the radios antenna connector. There will be a set of audio input rca jacks. Take the audio output from the external device and plug it in here. Then just tune your radio to the frequency that the modulator operates on and you are done. Good luck with the install!
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
