Stereo Wiring Code, 2000 Accord
tln666
Posted: August 20, 2003 at 4:57 PM / IP Logged
Hello all!
Does anyone have wiring codes for a 2000 Accord Coupe factory stereo?  Has anyone run into problems with the instrument panel lights and parking lights not coming on with replacement of the factory stereo?  Any responses greatly appreciated!
-Tammy, AZ
profuse007
Gold - Posts: 2,015
Posted: August 20, 2003 at 5:04 PM / IP Logged
i remember that there are diagram on the top of the stereo deck of 98 accord v6. check with your fuses, most likely you short something
Houston,TX
tln666
Posted: August 20, 2003 at 5:19 PM / IP Logged
Thank you for the quick response.  I usually check fuses first after a problem as such and before I seek help (don't want to look like an idiot).  All fuses OK.  Do you think it's the Light Multiplex Control Unit?  Hmmmmmmm...
Thanks!
Tammy N, AZ
profuse007
Gold - Posts: 2,015
Posted: August 21, 2003 at 5:43 AM / IP Logged
i dont think the lights have to do anything with the radio unit. it has to be the fuses, check them carefully or with a DMM continuity test.
Houston,TX
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
