Antenna woes
Sandlapper
Posted: August 23, 2003 at 8:30 PM / IP Logged
Hi All,
I have a defective power antenna on a 94 Lincoln Mark VIII, I would prefer a new universal antenna (cheap) instead of a oem replacement (costly),BUT I have two problems. First is a low voltage power supply(about 5-6 volts) and Secondly there are two(yes,two) power supply wires. One signals antenna to go up, the other sends it down. Any suggestions?
(I'm a newbie, but have a grasp of basic electronics..diodes,relays,etc.)
Thanks in advance for any help on this!
94 Mark VIII
What gauge is chickenwire?
Ketel22
Silver - Posts: 976
Posted: August 24, 2003 at 1:16 AM / IP Logged
get a stationary antenna?>
Quad L Handyman services
Sandlapper
Posted: August 24, 2003 at 8:04 AM / IP Logged
lol, that's my problem! I've GOT a stationary antenna.
94 Mark VIII
Ketel22
Silver - Posts: 976
Posted: August 24, 2003 at 2:31 PM / IP Logged
what exactly are you trying to do, im confused, you have a power antenna and are trying to replace it with a stationary antenna? or you have a stationary and are trying to install an power antenna, or what?
Sandlapper
Posted: August 25, 2003 at 4:56 PM / IP Logged
The motor has quit and the mast will not go down. I'm hoping someone can suggest a relatively easy fix to use a much cheaper universal power antenna. Metra shows a replacement antenna, it will fit, but this will not work with the factory low voltage double power supply(one for up and one for down)(versus normal single power lead @ 12volt).
94 Mark VIII
Sweekster
Silver - Posts: 481
Posted: August 25, 2003 at 5:56 PM / IP Logged
You may need to add a low voltage trigger to convert that signal to a 12 volt signal.  Peripheral Electronics has triggers that you may wanna look at.
Duane...
If you think you're confused, imagine how you feel.   Antenna woes -- posted image.
Sandlapper
Posted: August 25, 2003 at 6:48 PM / IP Logged
THANKS for the info!
Would I be able to combine both power supplies to one trigger? If so, would I need a diode on each line to isolate the signals from each line (one signals up, the other down), or is this neccessary?
94 Mark VIII
Sweekster
Silver - Posts: 481
Posted: August 25, 2003 at 8:35 PM / IP Logged
I think you should be able to combine signals (but someone else in this forum could possibly find out for sure).  If not, you could possibly add the diodes (or maybe a relay)  in between the low volatage signals and the trigger ( I would double check for sure though).    I would start with just the trigger and then if it still stays up then try the diodes.  Good luck.
Duane...
Sweekster
Silver - Posts: 481
Posted: August 25, 2003 at 8:38 PM / IP Logged
If all that fails, you may just want to try and find another 94 lincoln.  From what i remember, the town car and continental also used the same antenna.
Duane...
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
