Amplifier Ohms Question
wmosher
Copper - Posts: 28
Posted: August 26, 2003 at 9:17 PM / IP Logged
I have a question reguarding ohms. i see the specifications on amplifiers, and it kinda confuses me. I thought i had the ohms formula down pretty good, but im kinda confused. Take these amplifier specifications for example:
Product Features:
MAX Power (2 Ohm) 600w X 2
RMS Power (4 Ohm) 220w X 2
Bridged Power 440w X 1
Ok, so say i have 2 4-ohm speakers bridged, so that makes one channel, correct?. does that still mean im only getting 440watts? or since it would be down to 2ohm's, am i getting the complete 1200watts x 1 max?
nedgeworth
Silver - Posts: 264
Posted: August 26, 2003 at 9:20 PM / IP Logged
You are getting 440w RMS. Probably less than that being a Boss amp. How do u have your speakers wired? One to each set of speaker outputs??
wmosher
Copper - Posts: 28
Posted: August 26, 2003 at 9:22 PM / IP Logged
as of now, i have them bridged. both positives on one channel and both negatives on the second channel. which i tohught would drop the ohms down to 2, and give me the max output power
benjaminthe1st
Member - Posts: 22
Posted: August 27, 2003 at 12:33 AM / IP Logged
if you are running 2 4ohm subs in parrallel (+) to (+), (-) to (-) you would have a 2ohm situation bridged the amplifier would see 1ohm.  Even if you are running the two subwoofers independently wired each positive going to a common connection i.e. ch 1's (+), and the negative going to ch2's (-) you are still showing the same load.  The amplifier is likely to be unstable especially at increased levels, and is apt to get hot or go into protection.  If you were running DVC's I'd just suggest running one sub ran paralel per channel, but that isn't the case.  Be careful to monitor the amp, if you're in a sealed application you're more likely to get it to go into protect then a vented application.
Discount Car Stereo
23446 Pac Hwy Kent, WA 98032
206.824.5875
Resonant Engineering, Orion, Planet Audio, Soundstream, Panasonic, Pioneer, Rockford Fosgate, Compustar, DEI,Toucan, Matrix Other lines
muzikmannn
Posted: August 27, 2003 at 8:42 PM / IP Logged
your running both subs paralleled which is 2 ohm and your running the amp bridged. This amp will only be stable at 4 ohms when bridged or 2 ohm when not bridged. You need two 8 ohm subs parrelled for a total of 4 ohm runn9ing accross that amp of your bridged as you have it. If you keep the amp like it is and go crankin it then your gonna fry the amp. It will go into thermal runaway and say goodbye!!!!
Ketel22
Silver - Posts: 976
Posted: August 27, 2003 at 10:56 PM / IP Logged
all this depends i have a pos sony that is 4channel but i have both channels bridged with  2 4ohm loads on each, the amp is seeing 2 2ohm loads and it plays almost seamless.
Quad L Handyman services
nedgeworth
Silver - Posts: 264
Posted: August 27, 2003 at 11:03 PM / IP Logged
Yeah that is fine it will work the same on that boss amp as the setup you've got there on ur sony. Most of these amps are 2ohms stable stereo but not in mono.
wvsquirrel
Gold - Posts: 1,237
Posted: August 28, 2003 at 12:52 AM / IP Logged
Ketel22, it's the "almost" in "almost seamless" that will eventually fry that amp, and possibly your subs. Why not replace it with a better amp that's stable at your ohm load?
What part of MD are you from? Walkersville raised myself.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
italnpimp59
Silver - Posts: 427
Posted: August 28, 2003 at 7:27 PM / IP Logged
yeah if u got two 4ohm subs....wire them in stereo(4 ohms per channel)  if you wire them in parallel that would read a 2ohm load mono to the amp...and u will not have an amp much longer!  not with that amp anyway!
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
