rockford's 3 channel from 2channel amp?
Ketel22
Silver - Posts: 976
Posted: September 23, 2003 at 8:59 PM / IP Logged
http://www.rockfordfosgate.com/rftech/library/2000/3_Amplifiers/MAN2616A_PowerAmp_MAN.pdf
can any body explain what is trying to be done on page 20 of the manual? and also the ohm load that would be on each channel?
Quad L Handyman services
bberman1
Gold - Posts: 2,314
Posted: September 23, 2003 at 9:22 PM / IP Logged
They are running a tri mode configuration; here is a good tutorial http://www.eatel.net/~amptech/elecdisc/trimode.htm
Ketel22
Silver - Posts: 976
Posted: September 23, 2003 at 11:04 PM / IP Logged
thanks for the link im still lost though. I am using the rockford 1000a 2channel amp if i hooked my three infinity kappa's 12.1 to the amp would one of the subs have a greater rms from the amp than the other two? what would the total load be on each channel if the subs a svc 4ohm?
Sweekster
Silver - Posts: 481
Posted: September 24, 2003 at 9:49 AM / IP Logged
In that setup they are running two speaker from two channels and then one speaker from both channels (bridged).  It's kinda like using the amp to power 2 6x9 speakers and running a sub from both side.  It would (for example) drop the load on the 6x9's to 2 ohm and keep the sub at 4 ohms since you're using the positive on one channel and the negative on the other to run the sub.  In other words, its like running a sub in bridged mode but you also add a speaker to each channel.
Duane...
If you think you're confused, imagine how you feel.   rockford's 3 channel from 2channel amp? -- posted image.
wvsquirrel
Gold - Posts: 1,237
Posted: September 24, 2003 at 2:03 PM / IP Logged
Just remember to keep a minimum of a 2ohm load on the stereo channels, and 4ohm on the bridge
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Ketel22
Silver - Posts: 976
Posted: September 24, 2003 at 8:51 PM / IP Logged
thank you squirrel i can understand that
wvsquirrel
Gold - Posts: 1,237
Posted: September 25, 2003 at 11:45 AM / IP Logged
no prob
Squirrel
the12volt
Administrator - Posts: 3,959
Posted: September 25, 2003 at 12:40 PM / IP Logged
Impedance is relative to frequency. The diagram doesn't show the impedance of the stereo speakers nor does it show the impedance for the speaker wired in mono, it only shows the lowest recommended speaker impedance for each. If all speakers had a nominal impedance of 4 ohms and the high pass and low pass frequencies for each filter were the same, for example 80Hz, the amplifier would see a 4 ohm load per channel from 80Hz and up and a 2 ohm load per channel from 80Hz and down. If the low pass frequency for the speaker wired in mono was 100Hz and the high pass frequency for the speakers wired in stereo were 80Hz, the amplifier would see a 1.33 ohm load per channel between 80Hz and 100Hz,  and from 100Hz and above it would see a 4 ohm load per channel, and at 80Hz and below it would see a 2 ohm load per channel. Obviously if the amplifier is not stable below 2 ohms per channel then overlapping crossover points in this configuration using all 4 ohm speakers would not be recommended.
rockford's 3 channel from 2channel amp? -- posted image. the12volt • Support the12volt.com
