Major Install
ADVCustominstll
Member - Posts: 6
Posted: September 23, 2003 at 11:21 PM / IP Logged
I just aquired  12      YES   12
Rockford Fosgate TRF2215 - subwoofers, (cast 15", dual 1.4 ohm VC, 2000 watts)
I also have 20 Rockford Fosgate 1501BD Mono Class amps.
Now to my question
Each subb is 1.4 ohm and  the amps are 2 ohm mono stable.  I would have to use the BD link and use 2 amps per sub.
How would I supply enough Power to these amps to feed the beasts?
If each amp recomends a 4 gauge with a 150 amp fuse wouldnt I have to run 3/0 to a load of Batts and caps to power them alone with 2 indepen. High Out Put Alternators.
Any Help would be help full...
ADVCustominstll
Member - Posts: 6
Posted: September 23, 2003 at 11:42 PM / IP Logged
AS soon as I posted this I noticed that I made a mistake. IM srory
The power for each subb should be 2000 Rms and 5000 Max and changes ti to 4 amps per subb.
I should have read the manual slower and not gotten excited.
Maxst
Silver - Posts: 866
Posted: September 24, 2003 at 7:06 AM / IP Logged
I have to say one time....D@MN!!!!!
what the heck are you gonna put that in?
I would say multi-hi-output alt and batt setup, thick power and grounds.
 whats the HU?
I need quality equipment, feel free to donate.
Ketel22
Silver - Posts: 976
Posted: September 24, 2003 at 11:08 AM / IP Logged
wouldn't two of those amps be putting out 3000wrms at 1ohm? there fore using two amps per subs is sufficient?
Quad L Handyman services
ADVCustominstll
Member - Posts: 6
Posted: September 24, 2003 at 12:06 PM / IP Logged
Its going in a 1994 Isuzu Rodeo 4x4 Red has only 400 MIles on it Lowered, Air Bags, Custom Paint, Custom Interior, and to many other mods and customs to list.
I have from right behind the driver seat and Pass seat all the way back.
The Pass seat has been removed for a custom Radio install Area, MIxer, Equilizer, Remote Bass, Power gagues etc.
Each Vs is 2000 watts rms and ther eis 2 vc. So i would need 2 amps per vs. So 4 per sub.
What size of Ground and power wire did you have in MInd Maxst
ADVCustominstll
Member - Posts: 6
Posted: September 24, 2003 at 2:42 PM / IP Logged
I just got done doing the Measurements and I can fit all 12  15's in my suv with an amp rack and batts.  Havent figued out air space totaly yet but the whole rear will be packed. LOL
I have ordered 10  Stinger Power2 dB at  250 per.
"Saved up for 5 years for a KILLER stereo"   20 g to blow "
Would lvoe to hear any suggestions
ADVCustominstll
Member - Posts: 6
Posted: September 24, 2003 at 2:52 PM / IP Logged
I traded a friend of mine for another 4 Rf 1501db amps he had in stock so I can run 2 per subb
Also Ordered
(2) Rockford Fosgate Type RF CPSR
Battery Isolator/Regulator
(4) Rockford Fosgate Type RF CPCC40
Stiffening Capacitor
he he thank god I got a damn good credit rating
he he
Maxst
Silver - Posts: 866
Posted: September 24, 2003 at 3:27 PM / IP Logged
sounds like you have it all planed out.
mj239air
Copper - Posts: 153
Posted: September 24, 2003 at 4:35 PM / IP Logged
If you are going to use more than 1 amp per sub, you are going to ruin your subs and you will have to blow another 20,000. I can think of many other ways to spend 20,000 and still have a killer system. I know from experiece since I have spent a lot and have a killer system, but no where near 20,000. Might want to rethink the amps and find some that have the power you are looking so that you are using only one per sub!
tdsteele
Silver - Posts: 393
Posted: September 24, 2003 at 6:56 PM / IP Logged
Just an opinion but if i was spending that kind of money on a system, i wouldnt be here asking questions about it, i would find a very good install shop and let them do the whole thing so that way i know it would be right plus have a warranty to boot without any of the headache!!!!!
