LOC's and ground loop suppressors
luthier
Member - Posts: 10
Posted: October 21, 2003 at 11:28 AM / IP Logged
I have squeezed about all the whine I can out of my system with layout and grounding but there is still a little left.  One leg of the stereo has the signal going from the stock HU/amp to a preamp/eq by way of a line output converter.  My question is: does the LOC also act as a ground loop noise suppressor or could I put the latter in series for additional benefit?  FWIW, Here is a link to a complete description of the install:
http://www.ziaguitars.com/tsx.htm
Thanks, Skip
luthier
Member - Posts: 10
Posted: October 21, 2003 at 11:31 AM / IP Logged
the website won't load on my machine.  Try http://www.ziaguitars.com/tsx.htm
go2pac
Copper - Posts: 179
Posted: October 21, 2003 at 10:52 PM / IP Logged
The grounds on a LOC are for signal ground reference and should only be grounded when you don't have sound coming from the amp which are typically really old amps. Amps now a days don't need the wires grounded. A good LOC has a ground loop designed into it.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
luthier
Member - Posts: 10
Posted: October 22, 2003 at 5:30 AM / IP Logged
Any recommendations on the best LOC for my application?
Thanks, Skip
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
