low pass crossover
paper
Member - Posts: 7
Posted: November 02, 2003 at 4:29 AM / IP Logged
I pararell my 2 x 4 ohm speaker, it would be 2 ohm load.
My question is, If I want to apply the passive crossover in my speaker,... which chart should I use 4 ohm or 2 ohm?
And what should I use, narrow band pass or band pass crossover for mid range(not mid bass) speaker?
DYohn
Moderator - Posts: 10,741
Posted: November 02, 2003 at 8:56 AM / IP Logged
If you plan to run 2 mids in parallel, build your passive crossover for the 2 ohm load.  That way you only need to build one circuit.  Use the "bandpass" formulas for a typical midrange speaker.  The high pass section (low frequency filter) is generally more critical than the low pass section in terms of "getting it right" for the particular drivers you plan to use.
The disadvantage, of course, to using passive crossovers instead of using an active filter on the low level side is passive circuits are very difficult to adjust, as you must physically remove and replace components if the sound is not right the first time...
Good luck.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
