ported box size
tclaus
Posted: November 10, 2003 at 7:29 PM / IP Logged
I made a ported box with 3.1 cubic ft volume because some friends who maybe don't know exactly what they're talking about said that the bigger the box, the bigger the sound.  anyway, they also said you can use a rectangular port in place of a circular port of the same area without any problems.  so i did that too.  and also i didn't want to make it smaller than 1 inch wide, so that meant i had to make it long enough that it hit the back wall , turned the corner, and came about halfway to the front again.  i've always thought that the larger area of the port, the longer it has to be to be tuned to the same pitch, but a car audio guy at bestbuy just told me it's the other way around, that the two are inversely related, so what is right?  anyway about the box, it has a 1200w audiobahn 12" ultra excursion in it, and it sounds not like it should, i'm pretty sure, and there is almost no air moving in and out of the port.  should i chop the ends off the box and make it smaller?  is it better to have a round port than a slot?  what is the optimal diameter of a port?
thanks a lot for any help.
Ketel22
Silver - Posts: 976
Posted: November 10, 2003 at 8:43 PM / IP Logged
if you change the port you should be fine. make the port whole larger and shorter. either round or square all depends on your preferences. i believe square are usually used more for SPL setups.
Quad L Handyman services
tclaus
Posted: November 10, 2003 at 10:45 PM / IP Logged
ok well then what is a good port length calculator to use, the few that i have found say to make the port length longer as you put in a bigger diameter port.  about what frequency to tune it to, i have seen somewhere that if you tune it to a frequency that is higher than the lowest frequency you put into the sub, then the sub could be damaged, so that is why originally i tried to tune it to around 23-25 hz.  i guess that makes sense, but i really don't know enough about that to know for sure, so what do you guys think
forbidden
Platinum - Posts: 5,354
Posted: November 10, 2003 at 10:52 PM / IP Logged
OMG dude, be really careful. The box is the most important part of the bass equation, it will make or break the subwoofer. Your best bet is to contact the audiobahn tech dept and ask them for the proper box parameters for your particular sub or even tell them what you have and ask them to design the port (if applicable) for your application. This may get you on track for the bass you seek.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
