checking amp output w multimeter
Quick
Member - Posts: 17
Posted: July 23, 2002 at 5:42 PM / IP Logged
Can i check my amp output with a mulitmeter and if so how? Set the meter to range and contact to amp outs right?
Playtime
Posted: July 23, 2002 at 7:57 PM / IP Logged
set MM to A/C voltage....play some tunes and watch peak voltage....square this then divide that number by the impedance load. This gives a close idea.
good luck
