Four 10'' Subs
Digger67
Member - Posts: 23
Posted: November 17, 2003 at 9:44 AM / IP Logged
Hello all,
I am wondering if I would loose sound from my 2 10" subs at 4ohms each wired to 2 ohms, if i wired 2 more in and wire 2 X 2 in series and the 2 pair in parallel. I guess this would take me back to a 4 ohm load on the amp and would losee some boom. I am running a RF Amp pushing 377RMS and the subs are 10" Pioneer's. Any Ideas on how to get these to maintain a 2 ohm load or should I just break down for another amp? Dang what way to go.
Thanks for any info in advance.
Digger
forbidden
Platinum - Posts: 5,354
Posted: November 17, 2003 at 3:48 PM / IP Logged
Get a bigger amp. By the sounds of things you will need a different wiring method for 4 subs. If you are going on the 4 sub path, make sure all of the subs are the same.
wvsquirrel
Gold - Posts: 1,237
Posted: November 17, 2003 at 7:22 PM / IP Logged
What is the make and model number(s) of your subs so I don't give you the wrong info...
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Digger67
Member - Posts: 23
Posted: November 17, 2003 at 8:42 PM / IP Logged
The Pioneer subs are the new ones with the Carbinfiber cones ??TW-255-VC?? Single voice coil. But the way I am thinking is I will have a 4ohm load and not the 2ohm load for the full 377rms
   O <sub
      O--------O        O-------O
      |              |____|            |
     (+) Amp                         (-)Amp
I hope this works this would give me a 4ohm load would it not     Oh -------- and  | | are wires
Digger67
Member - Posts: 23
Posted: November 17, 2003 at 8:44 PM / IP Logged
Ah carp thats not what i had in mind
      O-----------O           O------------O
Amp is a Rockford 351M Mono amp
Yeah like this would be a 4ohm load ????
Thanks again
Digger
wvsquirrel
Gold - Posts: 1,237
Posted: November 17, 2003 at 8:58 PM / IP Logged
To wire (4) 4ohm SVC's together to a mono amp for a 4ohm total load, you would need to wire like this...
Four 10'' Subs -- posted image.
(image courtesy of Rockford Fosgate's Wiring Wizard)
Squirrel
Digger67
Member - Posts: 23
Posted: November 18, 2003 at 1:44 AM / IP Logged
Thank you very much for this info. Now will sound get better or will it get worst. If amp is stable at 2Ohm load with the 2 subs wont it cut out some of the Pound at a 4 ohm load. Sorry things I need to ask before doing this.
bberman1
Gold - Posts: 2,314
Posted: November 18, 2003 at 11:26 AM / IP Logged
What model amp and sub do you have? If your amp puts out the same amount of power at either 2 or 4 ohms then it won’t matter which load it has on it, you will still get the same sound quality at either load. But if  have 2 subs running at 375 watts @ 2 ohms then each sub is getting 187.5 watts each. Now if you add a total of 4 subs then each sub would be getting about 94 watts each. Now that’s assuming that your amp puts out the same amount of power at both 2 and 4 ohms. To help us figure out how to optimize your setup we need the exact model #'s of both your subs and amp.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
