What speakers to use with 4 channel V12 amp
trini
Member - Posts: 7
Posted: November 26, 2003 at 12:52 PM / IP Logged
wat mids and highs should i use while running them wit a 4 channel V12 amp
yo, was gwanin
bberman1
Gold - Posts: 2,314
Posted: November 26, 2003 at 12:56 PM / IP Logged
What is the model # of your amp? What kind of music do you listen to? And what is your budget?
trini
Member - Posts: 7
Posted: November 26, 2003 at 1:02 PM / IP Logged
i dun even know da model #, another question should relays be used while wiring up a system, does it make a difference?
yo, was gwanin
bberman1
Gold - Posts: 2,314
Posted: November 26, 2003 at 1:16 PM / IP Logged
I would suggest you take a look at MB Quart, Focal, Eclipse, and Diamond Audio. As far as the relay goes it depends on the number of components you plan on using. I generally add a relay on anything over 4 components. If you want to use a SPDT relay below is a diagram of how to wire it .
Positive Input-----> Positive Output Relay Diagram:
• 87 - Constant
• 86 : GROUND
• 30 - Remote Wire Accessories ( amps, EQ's, processors )
• 85 : Remote Input from HU
• 87a: NOT USED
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
