General Sealed boxes
rockfordfossie
Member - Posts: 25
Posted: July 25, 2002 at 9:38 AM / IP Logged
Why are sealed boxes trapezoid shaped and does it matter if it is rectangular or trapezoid.
Does anyone know what, Dacron, is???
ZX2's KICK A $ $
mobiletoys2002
Gold - Posts: 1,050
Posted: July 25, 2002 at 6:18 PM / IP Logged
no a box can be any shape and dacron is a brand of fiber fill used to slow the waves down in a box to make the sub think the box is bigger.
NyxBass
Silver - Posts: 226
Posted: July 25, 2002 at 7:18 PM / IP Logged
The reason they are made trapezoid is to prevent standing waves - The angled baffle prevents waves inside from bouncing around as easily. A rectangular box can work well, but should be well damped.
/NyxBass
GlassWolf
Copper - Posts: 365
Posted: July 25, 2002 at 10:23 PM / IP Logged
if the side of the box containing the driver is parallel to the side opposite teh driver, the sound waves will reflect off of the opposing surface, and cancel themselves out. This is called standing wave cancellation. It's a very bad thing.
Angling one of the two sides will prevent this. Adding polyfill does a similar thing by giving more surface area of a non-parallel nature from which the waves can reflect. Ployfill also has the added benefit of making the box seem larger than it rally is to the driver(s)
Dacron is a commercial name for a synthetic fiber. It's what polyfill is. Pillow stuffing.
While you can make a square box, most times it doesn't work as well, and you need to do tricks to it so its not parallel inside the box, like lining the enclosure with "egg-crate" foam.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
