Amp choices
bigtruckdriver
Member - Posts: 7
Posted: November 26, 2003 at 9:49 PM / IP Logged
I have recently been given a 10" subwoofer from a bazooka tube and 2 older 12" Kicker subs, and I plan on installing the 12" subs (1 first, then the other later) in my 1997 Chevy S-10 Regular cab.
This wil be the first time that I have attempted the installation of such a system.
I will be making the enclosures myself but I am having trouble making a decision on what type of amplifier to choose.
At the present, I have the factory original speakers in the dash and doors. I believe that these do not require further amplification? The head unit is a Pioneer, not sure of the model, 35w per channel, 4 channels. I need to check on the available outputs on this model.
I think that I just need to amplify the 2 subs so I was thinking of getting a mono amp and wiring both speakers (parallel or series?) to the one amp.
It does seem that there are many 2-channel amps out there that are cheaper than the mono amps. Would it be OK to use one of these amps with either the 2 subs wired to each output or would I need to bridge the outputs together to boost power and then split them between the subs? Obviously I do not require steteo for the bass.
As you can tell, I'm confused by the choices out there. I'm used to fixing computers, not subs!
manning58
Copper - Posts: 52
Posted: November 26, 2003 at 10:23 PM / IP Logged
It all depends on what kind of speakers you are talking about, and the power handling of them.  Are they 2 ohm or up to 8 ohm.  There are many factors involved here.  I would recommend that if they are powerful enough speakers say at least 300 rms that I would use a mono amp and throw lower ohms at them but then again it just depends on what kind they are.
Niko Suave
Self Installer
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
