Alpine CDA-9813/9815
DjIQ
Copper - Posts: 107
Posted: November 27, 2003 at 11:14 PM / IP Logged
Has anyone installed either of these head units? Do you have to have a fused 12V(+) directly from the battery even if your not hooking up speakers directly to it, Im just using  the RCA preouts and all my speakers will be hooked up to amps.
flatulatta
Silver - Posts: 356
Posted: November 27, 2003 at 11:34 PM / IP Logged
i installed an alpine and im pretty sure u need that 12v b/c i think its the main power source
SoundFX411
Copper - Posts: 153
Posted: November 28, 2003 at 8:30 AM / IP Logged
You have to fuse the 12v power but you don't have to go directly to the battery if you are using the RCA outputsand not the amp installed in the radio
si90lude
Member - Posts: 24
Posted: November 28, 2003 at 4:17 PM / IP Logged
i agree with SoundFX, the shop in witch I work sells alpine Therefore I have installed hundreds. As long as you don't plan on using the internal amp, you are fine wiring it behind the dash, make sure you turn off th internal amp in the menu, this will cut down on heat Alpine CDA-9813/9815 -- posted image.
DjIQ
Copper - Posts: 107
Posted: November 29, 2003 at 8:38 AM / IP Logged
Thanks Guys!!!
Alpine Guy
Platinum - Posts: 2,478
Posted: November 30, 2003 at 11:09 PM / IP Logged
you don't even need the fuse actually, you already have 2 in the fuse box protecting itAlpine CDA-9813/9815 -- posted image., but hey, 3 never hurts.  I always leave it there.  Make shure you turn off the internal amp by holding the "F" function button for 3 seconds and scroll through the settings till you get to the amp setting.
Have fun! you got a sweet deck there, , i have the cda-9815 and i love it, , i only wish my gear shifter wasn't so close to my head unit, cuz then i would have a cda-7998 with the phantom face.  Oh whell.
si90lude
Member - Posts: 24
Posted: December 02, 2003 at 12:41 PM / IP Logged
too bad your shifter is in the way, I have a cda-7998 and wouldn't want anything elseAlpine CDA-9813/9815 -- posted image.
Alpine:
cda-7998
mrd-m500 (soon to be 2)
mrv-m200
mrv-f200 (soon to be f540)
2 R series 10's (SOON TO BE 4)
2 sets of 61/2" R series components (using 1 set of tweets)
`1 set of out of place but well blended 6 1\2" mb quart woofers.
Alpine Guy
Posted: December 02, 2003 at 9:00 PM / IP Logged
hehe, we both  have a lota boom si90lude my system includes:
CDA-9815
3 MRD-M500
3 SWR-1241D
MRV-F540
SPX-F17T <<getting for x-mas hehe
SPX-F13M
I just had to part with a CDA-7993 because the bass killed the suspension in the headunit and it got to the point where it wouldn't play anything.  *fairwell to my first alpine*
Thats what happends when you hit high 140's constantly haha
si90lude
Member - Posts: 24
Posted: December 03, 2003 at 4:27 PM / IP Logged
sweet, let me know how the x series sound, the store I work at doesn't stock them Alpine CDA-9813/9815 -- posted image.. We don't have too many sq guys round here.
Alpine Guy
Posted: December 03, 2003 at 9:46 PM / IP Logged
they are amazing, the imaging is spectacular, there is a different setting on the x-overs for every possible speaker placement.  Basically spending the $300 or so more was worth it because my music went from imagining the band was playing on my hood, to the band playing on my dash for real kinda deal.  Toonnes of bass output if you completely seal your doors.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
