navigator factory audio system
adrianmanjarrez
Posted: December 19, 2003 at 7:26 PM / IP Logged
it is possible not to bypass the original sistem so I can upgrade the amps and speakers using the factory setup.please help!!.
adrian
forbidden
Platinum - Posts: 5,354
Posted: December 19, 2003 at 7:41 PM / IP Logged
Anything is possible, it is just not recommended. Are you trying to improve the sq or improve the "loudness" of the system while maintaining a stock look?
adrianmanjarrez
Posted: December 19, 2003 at 11:18 PM / IP Logged
I just trying to get more bass out the rear woofer .,I change the original woofer for one  fosgate punch RFZ3408 8" 4 Ohms, but  I wonder if the original amp. (30-40w) will be adecuate. which amp. will work and how to install.
adrian
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
