Adding another amp
mark241
Copper - Posts: 101
Posted: December 22, 2003 at 12:56 PM / IP Logged
The system i have include the kenwood x859 deck, kenwood kac 7201 powering 2 phoenix gold tantrum subs and a kac 8401 powering a pair of Alpine Spx 177A. I was wondering what happen if I got another kac 7201, so that there is an amp per sub. What would be the advantages
mark241
Copper - Posts: 101
Posted: December 22, 2003 at 3:42 PM / IP Logged
Can anyone one tell me what it will do, will it increase the sub performace?
dcgc
Copper - Posts: 78
Posted: December 22, 2003 at 3:49 PM / IP Logged
yes it will. SQ and SPL. double the watts twice as loud (+3dB)If the subs can handle the watts of the amps.
2003 Silverado Ext. cab
Kenwood mp922
Kenwood kgc6042a EQ
JL Audio xr650-csi
MB Quart PSC 213
JL Audio 300/4
pair of JL Audio 12w6v2
JL Audio 1000/1
mark241
Copper - Posts: 101
Posted: December 22, 2003 at 4:30 PM / IP Logged
How will it benefit the SQ portion? As for SPL the subs can take about 200 watts RMS and each will put out about 300 watts clean power (0.08%THD)
forbidden
Platinum - Posts: 5,354
Posted: December 22, 2003 at 5:02 PM / IP Logged
Downfall is that you'll have a hard time setting the subs to be the same, are they in a coupled chamber box or a separate chamber box?. If you are in the market for another amp, find one that is big enough to drive both with ease, that would be your best bet.
mark241
Copper - Posts: 101
Posted: December 22, 2003 at 5:05 PM / IP Logged
right now there sharing the same chamber in a sealed box. The reason I want the new amp is so that I can fully power each sub with clean power
forbidden
Posted: December 22, 2003 at 5:33 PM / IP Logged
With a coupled chamber box like yours it is best to use one amplifier only, find yourself a dedicated sub amp that is stable to 2 ohm mono and gives you the desired "wattage" that you are looking for. A little too much power is better than not quite enough.
mark241
Copper - Posts: 101
Posted: December 22, 2003 at 8:11 PM / IP Logged
Under the sound quality aspect, what will i gain? the one single amp can power the subs almost to their RMS rating. So will I still gain sound quality with this takin into consideration
forbidden
Posted: December 22, 2003 at 8:19 PM / IP Logged
Marginal at best, to gain a noticeable difference in output of approximately 3db results in an amp double the size. If I remember correct your amp is 150w x 2 and your subs are rated to 200w. Yes a larger amp will give you more power, hence louder, but it will also give you more control of the motion of the drivers at lower volume levels, hence increased sq.
jeffchilcott
Platinum - Posts: 2,483
Posted: December 22, 2003 at 8:25 PM / IP Logged
If you are looking so compete with this system i would only use one amp a amp that can handle the impedance of your subs   i didnt see what subs you have the impedance per sub...but i would recomend a nice orion or maybe a small zapco    if those are out of your price range look at MA audio
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
