factory power amp in Acclaim?
davis911
Posted: December 28, 2003 at 9:02 PM / IP Logged
I need help. Namely if there is a factory power amp in a 91 acclaim for the speakers and if there is what is the color of the wire to hook it up? The speakers I attached are lacking and this has to be the problem
Thanks all
Thank you
lspker
Silver - Posts: 503
Posted: December 30, 2003 at 9:01 PM / IP Logged
If I remember correctly the amps are attached to the front door speakers.  Two will be power and ground and the other two will be signal( speaker output from the deck)
davis911
Posted: December 30, 2003 at 10:19 PM / IP Logged
So what wires to what? I have hooked up the 8 wires to the 4 speakers but really poor sound could I have done something wrong here?
Does anyone know the wiring code or have a wiring diagram?
Shawn
Thank you
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
