Posted: December 28, 2003 at 10:03 PM / IP Logged
Posted: December 28, 2003 at 10:05 PM / IP Logged
Posted: December 28, 2003 at 10:11 PM / IP Logged
Posted: December 28, 2003 at 11:48 PM / IP Logged
Posted: December 29, 2003 at 12:28 AM / IP Logged
Posted: December 29, 2003 at 3:02 PM / IP Logged
Posted: December 29, 2003 at 8:52 PM / IP Logged
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
! Build the box to 1.25 cu.ft gross volume for each chamber. Make sure the box has a center divider (solid). Double up the baffle board if you can. Seal the inside of the box with silicone and spray paint the inside of the box. If you are putting terminal cups in the box, make sure you silicone them in as well. These subs spank, they have really really good sq, muti tone bass response, depth with authority and play to a good spl level as well. I used to match the Rockford BD1000 to these subs all the time and have never ever had an unhappy customer.
