Loudspeaker power ratings
DYohn
Moderator - Posts: 10,741
Posted: January 22, 2004 at 11:05 AM / IP Logged
Several people have asked me recently what power ratings listed on speakers really mean and where they come from, so I thought I'd post it here.   By the way, I currently work for a sound engineering company (that I am not supposed to name) most well known for certifying system performance and I have been in the audio/video industry for more than 30 years.
Commercial loudspeakers these days list two power ratings.  These are usually given in watts, since that is the most common way amplifiers are rated.  Power handling is actually a measure of the thermal characteristics of the speaker system, and really has nothing to do with how loud it will play.  The two ratings are called "Peak" and "RMS."
The "Peak" rating is determined by the physical size of the electrical wiring in the voice coil.   This is the number of watts at the speaker’s voice coil DC resistance rating that would produce the maximum amount of current the windings are capable of passing.  Peak numbers are dependant on the physical size of the wiring and the amount of time the current is present.  The AES Peak test is done with a 0.05 second (5 milliseconds) duration pulse of DC power.  This corresponds to a square wave signal pulse at 20Hz.  The peak rating is the maximum amount of energy the wiring can handle before it fails (i.e.: “smokes.”)
“RMS” in very general laymen’s terms corresponds to “average” in electrical theory.  The RMS rating of a loudspeaker is determined mainly by the heat dissipation capability of the loudspeaker’s voice coil system and by how much and how freely the system can move.  Better designed loudspeakers tend to have higher RMS ratings than more poorly designed ones that have the same peak ratings because they have better internal air flow.  Long-throw loudspeakers tend to have higher RMS ratings because they can move more.  It is the voice coil’s movement back and forth that creates cooling in the system and allows the heat generated by the current passing through the windings to be carried away from the windings.  Exceeding the RMS rating can cause the windings to heat up too much and separate, mechanically bind, or simply fall apart (i.e.: “smokes.”)
The AES/IEC RMS power handling test is somewhat deceptive as it is performed at single frequencies using tone generators, and not with full musical energy (pink noise.)  Some loudspeakers are more thermally efficient at certain frequencies than at others.  A manufacturer trying to over-rate a speaker in order to sell it to an unsuspecting customer might list the RMS value at the single best performing frequency (and you will never know that) but when the speaker is powered at that rating with full musical energy, it will blow.  Or they might just make the numbers up out of thin air.  Good manufacturers (those with reputations to protect) will list RMS power as an average over several test frequencies, giving a better real-life picture of the speaker’s thermal capacity.
In general, loudspeakers with higher power handling ratings tend to be less efficient, since they must use larger gage voice coil windings to handle the current.  Larger gage means less movement at a given current flow.  Efficiency is usually listed as “sensitivity” in a rating such as db/watt.  Higher sensitivity numbers mean the loudspeaker will always “play louder” at a given power input.
I hope this helps.  Next I’ll try to tackle my favorite audio myth, the notion that under-powering a loudspeaker is more dangerous than over-powering it.
customsuburb
Gold - Posts: 1,813
Posted: January 22, 2004 at 6:03 PM / IP Logged
I've heard that woofers blow when you overpower them and tweeters when u underpower them.
forbidden
Platinum - Posts: 5,354
Posted: January 22, 2004 at 6:16 PM / IP Logged
Speakers can generally  "blow" from a multitude of reasons, most people assume that a ripped surround on a sub is a "blown" sub. Most speakers however blow from excess heat buildup in the voice coils. If the heat cannot be removed or dissipated, many problems can arise, melted voice coil formers, melted voice coils, burned spiders, melted adhesives that hold components together, melted diaphrams and the list goes on. I have seen a magnet structure fall right off of a driver before after 16 hours of hard listening, the inner workings melted beyond belief. There are many different ways to blow a speaker, be it underpowering or overpowering, Dyohn will touch on that subject as he posted. I personally do not like to drastically underpower subs because the vast majority of users expect too much of them, this results in blown speakers due to improper use. If the user played his system within the given tolerances, he would have very few if no problems, but the vast majority of users do not do this, all they want is more bass and they usually recieve it along with the problems that will eventually arise as well. This perhaps is another topic for discussion as well.
DYohn
Posted: January 22, 2004 at 6:17 PM / IP Logged
In general, you heard correctly!  It is really, really hard to blow a woofer by underpowering it.  You have to work at it.  Blowing a tweet is very easy with under OR over power.
Wednesday, September 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
