Weird sound in Sub
tnpkhmerboy
Member - Posts: 6
Posted: January 28, 2004 at 10:03 PM / IP Logged
My audiobahn alum10q makes a really weird noise when it hits a low note. The noise can be described as a low pitch whistle. I brought it to different places and ran tests on it but everyone says that its ok besides making that noise. Whats up with that?
Please Help Me Out!!!!!!!!!!
tnpkhmerboy
Ketel22
Silver - Posts: 976
Posted: January 28, 2004 at 10:15 PM / IP Logged
is there maybe a hole in the cone?
Quad L Handyman services
customsuburb
Gold - Posts: 1,813
Posted: January 29, 2004 at 8:03 PM / IP Logged
make sure there is a good seal around the part where you mount the woofer and do you have a box with round ports? If your box is ported your problem could be port noise
DYohn
Platinum - Posts: 10,741
Posted: January 30, 2004 at 10:10 AM / IP Logged
Yep, sounds like a leaking enclosure to me too.  Or it could be bad adhesive on the surround (especially where the surround is glued to the cone.)
jeffchilcott
Platinum - Posts: 2,483
Posted: January 30, 2004 at 3:37 PM / IP Logged
leaking enclosure,    try putting a foam ring between the sub and wood on the box
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
