box building
RJay
Posted: August 07, 2002 at 12:13 PM / IP Logged
i have three 10 inch earthquake tremor subs and i wanna build a vented box for it ....there's a paper that came with it with the demensions to build one ported box, but how do i build one for three of 'em?  and i don't really understand how to use the theile-small parameters, can someone explain that to me .....and when building a box for three subs, do they all share the same air space or put a divider between them?  will it make a difference?
thanks
rjay
GlassWolf
Copper - Posts: 365
Posted: August 07, 2002 at 3:07 PM / IP Logged
try here:
https://www.the12volt.com/caraudio/boxes.asp
shared or divided won't make a big difference.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
RJay
Posted: August 07, 2002 at 4:01 PM / IP Logged
i still don't understand the rules of theile/small parameters, so do you think i should just build a box with three vents and devide the subs?  cuz they're all gonna be wired in parallel. here's the specs..   Fs=28Hz  Qms=4.726  Qes=0.483  Qts=0.438  VAS=1.6Ft  44 liters  Xmax=0.5"  85dB 1W/1M  Revc=6.3  Levc=6.3mH @ (1kHz)  single voice coil/8ohm    how would i be able to use that towards building a vented/ported box for three subs?
thanks
rjay
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
