98 Tahoe amp/sub help
Kayak Jones
Member - Posts: 15
Posted: February 09, 2004 at 12:35 PM / IP Logged
Did I do this right or did I screw it up. JBL 1200.1 mono amp. 98 Tahoe with oem alpine. 4g power from the amp to the +batt terminal. ground from amp to  luggage tie down in rear of vehicle. Remote wire from amp to blue wire in alpine wiring harness. Result:no power to amp. Switched remote to blue/with white stripe wire. Got power and promptly began blowing fuses in the amp. Never got sound. just blown fuses. Any ideas from the gurus would be greatly appreciated.
Teamrf
Gold - Posts: 1,031
Posted: February 09, 2004 at 1:21 PM / IP Logged
Gheck your wires....you always want to use the blue with white on the back of the radio for your remote turn on wire. The other wire is your power antenna.  Your ground may not be good. Make sure you have scratched all the paint of the ground, and made a good connection. Make sure you are also not drilling into lines in your car (gas line, brake line) Also check your fuse under the hood.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Kayak Jones
Member - Posts: 15
Posted: February 09, 2004 at 1:50 PM / IP Logged
I have switched the remote to the blue/white wire. thats when the fuses began to blow. Possibly ground related? Power line fuse to amp (inline 100amp is good) just the three 40 amp fuses on the amp itself are blowing. Assuming the ground is good, would speaker wiring to the subs have anything to do with this, and if not ,possibly bad amp?
forbidden
Platinum - Posts: 5,354
Posted: February 09, 2004 at 2:12 PM / IP Logged
Disconnect both the rca cables and speaker wires from the amp. Power the unit on / off again, if it still blowing fuses, it is a bad amp. If it is good, plug in the rca cables, if it blows fuses, chances are the rca cables have been clinched and are going to ground. Run a new temporary rca cable and see if the fuses still blow. If they do, chances are that you have a bad input stage in the amp. If the amp is Ok still, have a good look at the speaker wiring to see if it is going to ground as well.
Kayak Jones
Member - Posts: 15
Posted: February 09, 2004 at 2:32 PM / IP Logged
I'll give this a try this evening and let you know. Thanks for your suggestions.
Kayak Jones
Member - Posts: 15
Posted: February 09, 2004 at 2:39 PM / IP Logged
One more thing. The amp has to sets of terminals for speaker outs, 2 pos and 2 neg. With single voice coil subs 4ohm each, what are my wiring options for the subs (assuming i can get the@#$ ting to work). It is 2 ohm optimized and 1 ohm stable.
customsuburb
Gold - Posts: 1,813
Posted: February 09, 2004 at 6:23 PM / IP Logged
if you wire 2  4ohm subs to the single output of your mono amp you are going to be getting a 2 ohm load(this should be fine as long as its not too much power for your speakers).
customsuburb
Gold - Posts: 1,813
Posted: February 09, 2004 at 6:26 PM / IP Logged
sorry i was thinking of a mono amp. if your amps 4 ohm 2 channel output isnt too little power for your subs each then just connect one sub to each channel. otherwise you are pretty much out of luck unless your amp is a mono amp that has two sets of mono outputs. if this is so then I would just connect one sub to each terminal to get a 2ohm load.
Kayak Jones
Member - Posts: 15
Posted: February 09, 2004 at 7:31 PM / IP Logged
Update: Unhooked all speaker and rca cables. Re wired ground to a good source (seat belt bolt). Checked remote wire. (good voltage). Turned on car, blew 3 fuses. Checked all terminals with meter (all ok). Checked power wire for short (nothing visible and excellent voltage to amp)). Started vehicle, blew 3 more fuses. Checked everything else we could think of, then ran new direct power wire from amp to battery. Touched new wire to + terminal. Loud popping noise followed by smoke and OH SH#T, SOMETHINGS BURNING smell. The general consensus was that the amp was bad to begin with, because we couldn't find any other problems. If it wasn't, it dang sure is now. It was a refurbished JBL BP1200.1. Called the dealer and am taking it back tomorrow for a refund or exchange toward a different amp. Did we miss anything anyone else can think of and either way, thanks for the prompt input.
Kayak Jones
Member - Posts: 15
Posted: February 12, 2004 at 11:56 AM / IP Logged
Update: New amp works fine EXCEPT that rear door speakers were not working after amp install. They were working fine before and no wiring changes were made to install the new one. (the system was already wired for the one that was blown) now mind you that the speakers only didn't work when the cd was playing, they worked fine on fm. Also, Could not get any am radio reception after powering up the amp. So,  I switched the rear door speakers wire to the blue/white stripe wire that the remote turn on for the amp was wired to. presto, everything worked fine. Until this morning that is when all of a sudden I lost am reception again, (fm ok) plus the rear speakers are still working fine. I am stumped. Any and all suggestions welcomed.
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
