Woofers and Trunks
mcstw
Posted: August 09, 2002 at 3:33 PM / IP Logged
Dudes-
I have noticed in the last few years that vehicle manufacturers are making much better seals between the trunk space and passenger space of their cars. This is good for road noise reduction, but not good for someone who puts a sub in their trunk and wants to hear it. In my car, I have to fold down the seat in order to get the true bass response I want. It literally is about 3 db louder with the seat open. My 1984 Honda Prelude, back in the day, hit hard no matter what position the seat was in.
Has anyone else noticed this? How can this be gotten around?
I even went as far as removing the full range speakers from rear deck, leaving the grills there. I was hoping this would vent the bass into the car. It made a bit of difference, but I don't consider it a solution because I have no rear fill for mids and highs.
I also thought about a bandpass enclosure, vented right into the interior with a duct in the rear deck. Problem is, I like the accurate bass of a sealed enclosure. Bandpass is way to sloppy and "one note" for my taste.
I have noticed this in many cars, saturns, neons, mazdas, etc.
Is there an answer here, or do I just have to live with limited bass with the seat up?
Moderator - Posts: 12,488
Posted: August 09, 2002 at 3:53 PM / IP Logged
Fabricate an enclosure that has the subs on the back dash and the box underneath it. This would require you to refabrivate the entire rear protion of the back dash area, but this will eliminate the problem that you have.
GlassWolf
Copper - Posts: 365
Posted: August 10, 2002 at 10:24 PM / IP Logged
best solution I've used for these types of cars.
build a ported box.
fire the ports right through the back deck, so that the ports end right at the deck, and port into the cabin of the car.
This has a terrific effect. Otherwise you just need to vent that entire rear deck, re-cover it with headliner material, and put the sub box against the back seats, with the subs aimed at the rear of the car, to give the most room for resonation. Also consider using a large-volume box for higher SPL, and give it plenty of clean juice.
The Caprice/Impalla SS body GMs are the same way.   Those trunks are sealed like they were made for the Mafia.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
mikeymars
Member - Posts: 9
Posted: August 12, 2002 at 7:30 AM / IP Logged
This is a very subjective issue given every cars and subwoofer has different  acousticst.
 As example, I have a small "packaged" JVC subwoofer which I've used in several cars, usually under the passenger seat (t's a passive dual voice coil model, I drive it with a 2x30 amp).   In that position, the low bass it created was O.K., but nothing to get excited about.  However, I just put it in the trunk of a 1998 Pontiac Sunfire, and even though I was concerned that its sound would be "buried" behind the back seat, boy was I wrong - that  thing kicks now.
mikeymars
GlassWolf
Copper - Posts: 365
Posted: August 12, 2002 at 12:19 PM / IP Logged
that's because it now has a confined airspace, and enough room to resonate :)
-GlassWolf
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
