Bass Blocker Set up
Trent109
Member - Posts: 42
Posted: February 21, 2004 at 3:33 PM / IP Logged
I dont think i set this up right, is the bass blocker suppose to be on the other side of the crossover on the wf + side? heres a pictureBass Blocker Set up -- posted image.
sorry such a bad pic, but please help
Trent Hamilton
Trent109
Member - Posts: 42
Posted: February 21, 2004 at 3:40 PM / IP Logged
Dont know what happen with the pictures, so ill post them like this:
http://www.angelfire.com/ill/mypictures/IMG0081.JPG
http://www.angelfire.com/ill/mypictures/IMG0083.JPG
thank you
Trent
customsuburb
Gold - Posts: 1,813
Posted: February 21, 2004 at 4:55 PM / IP Logged
I don't think it matters. Either side would be fine I think.
Tcole
Copper - Posts: 92
Posted: February 21, 2004 at 5:27 PM / IP Logged
Why do need a bass blocker if you already have a crossover?
That is what your crossover is doing.
Tcole
Copper - Posts: 92
Posted: February 21, 2004 at 5:28 PM / IP Logged
If you do want one on the woofer, splice it in on the positive lead.
customsuburb
Gold - Posts: 1,813
Posted: February 21, 2004 at 7:07 PM / IP Logged
Tcole Trent 109 probobly wants a bass blocker because he dosn't want any bass going to his small speakers. His external crossover isn't filtering out the low frequencies, its just sending the lows to the woofer and the highs to the tweeter.
forbidden
Platinum - Posts: 5,354
Posted: February 21, 2004 at 7:21 PM / IP Logged
Tcole is correct, however he has also posed a good question. In this case the crossover looks to be a 2way passive device that will hp the tweeter and lp the woofer. It will not provide a hp on the woofer which is what the post seems to ask about. If these speakers are being amplified, then a hp crossover will be used, to block more bass, turn up the crossover frequency. If they are not amplified a basic cap can be installed on the positive lead to the woofer, a value of 200mf should work fine. If you can find a mylar non polar cap, that would work best for you.
customsuburb
Gold - Posts: 1,813
Posted: February 21, 2004 at 8:33 PM / IP Logged
Forbidden you are basically saying what I said about what the crossover is doing. Low passing the woofer and high passing the tweeter. He would not be using an external amp if he had bass bockers because there would be a high pass crossover on the amp.
Trent109
Member - Posts: 42
Posted: February 26, 2004 at 4:11 AM / IP Logged
it came with the whole speaker setup from infinity, so i figured it would be for the tweeter, but after i installed it i got to think that i might have messed it up just thought i would get your alls info
thanks
Trent hamilton
shredder130
Member - Posts: 41
Posted: February 26, 2004 at 11:18 AM / IP Logged
what would be the voltage on the capacitors?
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
