Unlock code for GM Radios?
bradsyukno
Copper - Posts: 52
Posted: February 24, 2004 at 5:14 PM / IP Logged
GMC Yukon 2003 with Bose system (RDS Head Unit)  Theftlock is on, tring to manually unlock the radio.
How can I unlock A GM radio once is taken out.  The code is supposed to be the last three digits of your VIN#, but what is the procedure in unlocking it?  Does anyone Know this.
Mr Hexed
customsuburb
Gold - Posts: 1,813
Posted: February 24, 2004 at 9:22 PM / IP Logged
It should tell you how to unlock it in your manual.
auex
Platinum - Posts: 5,041
Posted: February 24, 2004 at 9:25 PM / IP Logged
Who the hell told you it was the last three digits of your vin? It is programmed to the vin via databus.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
bradsyukno
Copper - Posts: 52
Posted: February 25, 2004 at 9:01 AM / IP Logged
I could not find how to unlock the radio in the manual.  Is this something that the car owner can do.  How do can I find what my unlock number is.
Mr Hexed
tee17
Copper - Posts: 93
Posted: February 25, 2004 at 12:38 PM / IP Logged
first what are you trying to do with radio. if you are putting it back in the yukon it should unlock itself because it is tied to that car. if you are giving it to someone or receiving it from someone, then they/you would have to take it to the dealer and see if the dealer can reprogram it to their/your vin via the databus. but you cannot just take that radio out and put it into another car because that radio tells you everything about the car it came in like tire pressure, xm radio etc. if you are the recipient then it might be cheaper to just get an aftermarket radio because we all know how much dealer prices can be, thats assuming they can do it. i have only heard of it being done once. hope this helps.
kgerry
Platinum - Posts: 3,455
Posted: February 25, 2004 at 4:46 PM / IP Logged
we do it all the time, all you need is a Tech II scan tool and you burn the VIN into the radio and then do radio setup.  If you are putting the same radio into the same vehicle then tee17 is right it will not see a conflict because the VIN matches, you want to put it in another vehicle or got it from another vehicle then you have to edit the VIN in the radio and then do radio setup.
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Tuesday, August 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
