Cap is killing my battery!
Lexx_dog
Member - Posts: 10
Posted: February 28, 2004 at 7:53 PM / IP Logged
I installed a 2 farad sting pro cap in my system and it kills my battery. I noticed that it doesnt have a remote turn on wire like all the others do.  What could cause this?
Ok heres my layout.
2gauge to the trunk connected to an optima blue battery then from the bluetop to the cap then to my orion 2100hcca.
it fixed my clipping problem from my subs but it kills my battery and leaves me stranded.
any help is appreciated.
thx Lexx
customsuburb
Gold - Posts: 1,813
Posted: February 28, 2004 at 8:12 PM / IP Logged
Does your display have a digital read out? If it dosn't then you shouldn't have to have a turn on lead. Do you have an aftermarket alternator? If you don't or if your amp is too big of a load your alternator won't be able to charge your battery, your cap, and power your amp.
DYohn
Platinum - Posts: 10,741
Posted: February 28, 2004 at 8:18 PM / IP Logged
Yep, that's what can happen.  It is one reason why caps can be a waste of money.  They just put extra load on yur charging system.  If your sub amps were drawing down your alternator, the only real fix is a high-output alternator.  Caps cannot solve "clipping problems" in subs.  What do you mean by this?
Lexx_dog
Member - Posts: 10
Posted: February 28, 2004 at 8:37 PM / IP Logged
Ok the cap has a digital readout on it. My subs fade in and out when i am at 3/4 volume. It does it when the cap isnt hooked up. When the cap is hooked up it plays fine and even louder. I have the orion's gain turned 3/4 up. I really dont wanna change the alternator in a lexus. i know thats a problem waiting to happen!
lexx
RufNUSD
Copper - Posts: 184
Posted: February 28, 2004 at 8:51 PM / IP Logged
The cap is not killing your battery. Yes it is a load, but if you leave your car parked and the battery dies?? Its not your cap unless the display remains powered up after you turn the engine off. Even still I dont think it would pull more than .1 amps.
Someone pass me that bottle.
auex
Platinum - Posts: 5,041
Posted: February 28, 2004 at 9:08 PM / IP Logged
I agree with RufNUSD. Unless the dispaly is on there is no way for the cap to kill your battery. All it does is store energy. What kind of vehicle do you have?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Lexx_dog
Member - Posts: 10
Posted: February 28, 2004 at 9:09 PM / IP Logged
When I pull my keys out and open the trunk the cap is still displaying power. it starts dropping power immediately after I pull the keys out.
wayland1985
Silver - Posts: 353
Posted: February 28, 2004 at 9:35 PM / IP Logged
Even if the display was on, it's an LED display.....and draws close to nothing....  It shouldn't drain an entire car battery if left 12 hours....  If it is infact draining your battery, it may be because your alternator is too small.  If the capacitor is drained after your playing the bass to hard, it's going to use battery power to recharge after you turn the car off.....even so, it shouldn't drain an entire battery...... Check the wires once more, maybe there's some metal to metal contact someplace along the length of the wire....
~wayland
wayland1985
Silver - Posts: 353
Posted: February 28, 2004 at 9:40 PM / IP Logged
Keep in mind too....if the ignition is off, the cap shouldn't be on.  Without a turn on wire, the cap is programed to look for a greater flow in power, since alternators sent 14 volts of current....When the flow increases, the cap senses that the car is on, and powers up......  maybe you can buy a cheap circuit breaker, and mount it near the driver, where you can access it.....attach the 2 gauge wires to it, and when you want your music, turn the circuit breaker on, if you don't want the music, switch the circuit breaker off.....that way not only do you have a nice "valet" switch, so nobody can play with your tunes when it is at the shop, and you won't have any drain on the battery when you don't want it to.....
~wayland
Maxst
Silver - Posts: 866
Posted: February 28, 2004 at 10:40 PM / IP Logged
Upgrade the alt, and get rid of the cap.
I need quality equipment, feel free to donate.
