sub install problem
saleengt
Copper - Posts: 73
Posted: February 28, 2004 at 10:47 PM / IP Logged
I hooked up the amp and subs and for some reason all im gettin is like a heartbeat feedback through the subs, they just keep subbing like a heart beats, and will not sub any music, is it a bad ground? or rcas are gettin interference?
Clean Install
Silver - Posts: 446
Posted: February 28, 2004 at 11:19 PM / IP Logged
what are you using for equipment?
If we learn from each success and
each failure, then we can improve ourselves
DYohn
Platinum - Posts: 10,741
Posted: February 28, 2004 at 11:22 PM / IP Logged
it's either a ground loop or you have the gain on your amp way too high.
saleengt
Copper - Posts: 73
Posted: February 28, 2004 at 11:32 PM / IP Logged
whats a ground loop and how do you solve it, im using a hitron amp and some hollywood subs.. the gain is only about 40 percent.
DYohn
Posted: February 28, 2004 at 11:42 PM / IP Logged
How did you set your gain?  Is it matched to the output from your head unit?  Where is your head unit grounded and where is your amp grounded?
Clean Install
Silver - Posts: 446
Posted: February 28, 2004 at 11:48 PM / IP Logged
a ground loop is more than one ground path where the differences in current potential of each path create a voltage differential
make sure that your ground is grounded to the frame...even the frame can have a differnces in voltage due to the current flowing through different circuit paths..
do you have an extra pair of rcas?
saleengt
Copper - Posts: 73
Posted: February 29, 2004 at 3:34 AM / IP Logged
the head unit is or i believe is grounded through the harness, I am not sure, but i did notice that if i pulled out the ground from the amp and turned the system on i would get feedback in the regular speakers, and i do have the mach 460 sound system with the mustang so those amps are on, becuase I am using the remote turn on wires for those amps too. the amp ground is to the frame, but is it possible that a non grounded deck is causing this problem? thanks
forbidden
Platinum - Posts: 5,354
Posted: February 29, 2004 at 4:00 PM / IP Logged
Back up the bus, post up exactly what you have installed in this vehicle, back to front, make the post as detailed as possible.
saleengt
Copper - Posts: 73
Posted: February 29, 2004 at 5:41 PM / IP Logged
the vehicle is a 97 ford mustang gt, now it has the premium sound, the mach 460 setup. I did not rewire, so the factory system is integrated with the aftermarket deck. I have a pioneer dehp 6500. Now i dont know if the deck is grounded or not. I used the premade harnesses and it may or not be grounded. Now I want to add an amp and subs. A hitron 2 channel amp and 2 hollywood excursions. Everything hookedup im gettin a heartbeat feedback through the subs, they are not playing any music just doing a heartbeat feedback. I tried taking the ground from the amp and seeing what would happen, instead i got engine whine in the regular mids, so i then unplugged the rcas and that removed the whine. So is it that the deck is not groudned and when i ground the amp, its trying to ground the deck through the rcas? thats why im gettin feedback in the subs?
Clean Install
Silver - Posts: 446
Posted: March 01, 2004 at 2:54 AM / IP Logged
If your deck is turning on its grounded...
when ever I install a deck I make a new ground....most of the time to the frame under the dash.
It seems to work for me..never have had a problem with any noise..knock on wood...:-)...a guy one time had a long ground wire for his amp just a little guy for a amp....and he had noise problems...I shortend the length a foot an the noise was gone....
