hooking up 2 amps
BangBang
Silver - Posts: 287
Posted: February 29, 2004 at 3:16 AM / IP Logged
hey YO, i already have one amp hooked up to 2 subs
i have a spare amp , spare amp kit, 2 xtra rca wires, xtra remote wire,
now i need a distirbution block for the wires
 i currently have a 8 guage wire,  can i split that 8 guage wire with the distribution block?
what else should i do?
forbidden
Platinum - Posts: 5,354
Posted: February 29, 2004 at 3:57 PM / IP Logged
Run the wire out your door and attach it to a stuffed dogs dog collar and head out for a drive.
BangBang
Silver - Posts: 287
Posted: February 29, 2004 at 4:36 PM / IP Logged
lolz
dont be a n****r, if ur being sarcastic i dotn need ur shee'ats here , u can bounce. dat aint even funny,
if u dotn knwo how to hook up to amps u should not read dis nub can't touch dis cpl !
SDmustang21
Member - Posts: 33
Posted: February 29, 2004 at 6:46 PM / IP Logged
what size amp do you currently have and what size are you thinking of putting in? (watts)
Buy it, install it, play with it. Then take it back out, read the instructions, install it better!
wvsquirrel
Gold - Posts: 1,237
Posted: February 29, 2004 at 7:51 PM / IP Logged
How about a list of your equipment (makes and models)... headunit, amps, speakers, subs, crossovers, etc. Let us know how you have it currently wired up as well.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
BangBang
Silver - Posts: 287
Posted: February 29, 2004 at 11:19 PM / IP Logged
ok right now this is wat it is
headunit :  JVC KD-5S00
amp kit : 8 guage
Subwoofers : dual 10" sony xplods   *XS-L101P5 *
amp : sony xplod 1000 watts   *XM-2165GTX*
X-TRAz
xtra amp : DHD 400 watt 2 channel
xtra ampkit : 8 guage
xtra RCA :  2 RCA Y Cables
SDmustang21
Member - Posts: 33
Posted: February 29, 2004 at 11:32 PM / IP Logged
1000 watts using an 8 guage! oh well..as long as it works...i would bump it up to using 4 guage for just that one 1000watt amp...
wvsquirrel
Gold - Posts: 1,237
Posted: February 29, 2004 at 11:36 PM / IP Logged
I agree with SDmustang21, you should be running at least 4 gauge to that amp. I'm not a fan of Sony's car audio by any means, especially their xplod line. But if it's what you wanted then go with it.
What were you wanting to do with the second amp? There's no way to bridge those amps together and combine the output to the subs, and running 1 sub from each amp would be pointless. If you were to do anything I would suggest running another set of subs from the second amp (although that would require running more wires and definitely a larger alternator, plus the subs)
Squirrel
